Hangar 9 ASW-20
  • I did remodel the trolley, as the insulation pipe on the vertical part either fly away during take off or prevent the trolley to be dismounted as there is too much tape...
    I doubled up the vertical part with a pieces of plywood and glued over some insulation foam for doors, look to be very satisfactory, I should test this soon
    Untitled by steffruelle, on Flickr
    • Question: with the recommended landing flaps has anyone mixed in any elevator, if so how much? The recommended Aileron throws seem to be excessive, any comments?
      • I am not using elevator mix with the flaps, but I do not put them down that much... I did not noticed a tendency for the plane to balloon when flaps are deployed, but I am using mainly spoilers on landing
        For the ailerons, throws are not excessive if you want to do a bit of aerobatics, I even coupled the flaps to the ailerons to have more authority (ailerons down -> flap down as the flaps don't move up...)
        Anybody has other views on this?
        • [ATTACH=CONFIG]n4495[/ATTACH]
          OK Gentleman, I am nearing the time to put her in the air.
          • WOW !!!!!!!!!!!!!
            • Question for all (especially Stephane): I wish to program mix so that my trailing edge is full flying in the down mode
              I have been on the phone with Horizon today asking them about programing MIX in my DX9 Black. I want to program in my acrobatic mode a flap/aileron mix. Horizon has yet to tell me how although they are still working issue. I wish to program mix so that my trailing edge is full flying in the down mode (as you all know, there is no upward movement on the flaps on this bird) Stephane ---> I know you have done this but I nor Horizon have been able to identify how.
              My quest continues, any words of wisdom would be greatly appreciated.......
              BobR
              • Bob
                I can send you my ASW20 file on my DX18 gen 2, you should be able to use it on your DX9 black if you have the last version of the firmware, PM me your email.
                in essence :
                sailplane type wings 2 ailerons 2 flaps
                channel assign
                1 left ail
                2 Right Ail
                5 right Flap
                6 L flap
                Channel input
                7 Aux3 LLv
                10 Aux5 Spoiler
                Camber preset not used 0 0 0 0
                Camber system input LLV
                Speed / Aerobatics flap up 0 Down 100% Ailerons up 0 down -25%
                Cruise / Normal flaps up 0 Down 50% Ailerons up 0 down -25%
                Thermal flaps up 0 Down 25Ailerons up 0 down -25%
                Mixing
                Ail > flap
                switch (flight mode) : switch D
                Speed left -50% right -50%
                cruise left 0 right0
                thermal left 0 right 0
                If you need clarification let me know
                • Stephane,
                  With your direction I have once again broke through the glass ceiling, lol Thanks again!!
                  I will now go completely through her and finalize all adjustments. If the weather will clear up I will get her out for her pre maiden pics. Additionally. Now I have to turn my attention to the trolley as it is not deep enough to carry bird - regardless of what esprit models says. Apparently the one recommended by horizon is not the one in the pictures which they show. Also, not big enough for the bird.
                  Slow going but progress being made,
                  Thanks Stephane!
                  Bob
ID:	4567 Click image for larger version
                    Just a teaser, here is yesterday flight, pict of the bird and snapshot of the vario log
                    For the trolley you can not go wrong with the horizon hobby one, they designed it for the ASW-20
                    Stephane
                    • BobR
                      BobR commented
                      PS. Doesn't the man get hot sitting there all day long)))))
                  • Stephane yes a huge tease.....
                    As for the trolly (http://www.horizonhobby.com/launch-t...20-p-han495509) they are all out of stock as (they have been pulled from stock - not the correct item (in Picture) being sold) I can't find one. If you know where one is I will be glad to order. Tried with Graves as well - pulled from stock. I think there has been a mix up on products somehow.
                    What was the altitude on the vary - I was not able to see left hand column...
                    Waiting for the sun to break I want to send you all pictures, I find her to be Beautiful
                    Bob
                    • Well guys I wanted to show you my patriotic spin on the ASW-20. Decals where designed by and purchased from Callie Graphics. Enjoy
                      • I LIKE THAT ! Callie comes thru again.
                        • BobR
                          BobR commented
                          Callie, placed her on their web page. I am honored
                      • Here is a video of last month with Miroslaw
                        • Hello All,
                          I wanted to show you all my Maiden Flight. I, of course, was very excited. The video was taken off of a cell phone so its not the best but I wanted to share. Thanks to all that have assisted me in putting her together.
                          Bob
                          • Congratulations Bob!
                            Thanks for letting us tag along on you're journey!!!
                            • BobR
                              BobR commented
                              Thank you sir! Its my first big bird and I am ecstatic with its flight characteristics
