Hangar 9 ASW-20
  • Originally posted by ARUP View Post
    It is 100mm deep 90mm from rear edge. 140mm wide at front edge. About 65mm deep at front. 180mm wide at the rear about 70mm from the end which is the widest part of tub.
    Thanks Arup! Appreciate it. Does the HH ASW use a belly hook (per scale) or a nose hook?
    Cheers,
    Barry
      Oh... if this will fit then give me a shout. I can make a glass tub for you. I can deliver it to an event or you pay postage but otherwise it will be free! The plastic tub I have has been used many times to pull glass parts and is starting to craze but I think I can get one or two more from it.
  • Originally posted by dbarrym View Post
    Cheers,
    Barry
    Belly hook because it’s setup for a electric prop drive in the nose.
    • you should be able to get the nose release from IFLYTAILIES
      RC sailplane and glider accessories: tow release for sailplane, glider, and tow plane
      LEN
      • NIB at its new home. I covered your address Len 😉
        • Time to shop for batteries and I’m guessing a new charger.
          I’m planning LiFe 6.6v packs, totally new to me, I’m looking for a reputable supplier/brand. Weight isn’t an issue as I need the nose weight.
          • You can call The Model Box, 205 978 8787, we keep LiFe 2200, 3000 and 4000mah 2S, we also stock the smart Chargers Single and Dual!
            • My order arrived sat, thank you
