  • Pretty impressive Gunny
    • The DA-215, Tundra tires, these tips, and then some wing slats...
      • Sinkhappens86
        Sinkhappens86 commented
        Don't forget stall fences and vortex generators!
      • gunny11
        gunny11 commented
        Never saw one with wing slats, but you forgot to mention the reinforcing corrugation on the control surfaces.
    • Variable pitch prop,
      • gunny11
        gunny11 commented
        LOL! wonder if Solo prop is still in business.
    • Ok, There will be a purchasing option on whether or not you want the stock rounded wing tips or the vortex drooped wing tips. The drooped wing tip version will include a separate plan sheet with supplemental instructions.
      • Don't forget stall fences and vortex generators!
        Kevin, Absolutely! 8 months ago Kevin mentioned these to me and I had no clue about any of this. Wasn't in any of my aeronautical design books. So, I've done a ton (months) of research on them, Size, spacing, angles, qty, location etc. Lower the stall speed by 8%. WOW! Talk about landing at a crawls pace! LOL. I'm definitely going to put these on my airplane. Just the cool factor alone would be enough!
        This will be an option that can be added to an already finished and flying model. Now I have something to do over the winter.
        • Once again,
          Pretty impressive
          • Added all kinds of links to the Cessna 185 page, Manual and parts sheet etc. Check It Out!!
            Go to Kits and scroll down to the 185 and click on the picture to enter. Ps. it's done!
            • As of post #215 the vortex generators are figured out and done.
              • This will be an optional kit laser cut out of .015" thick G-10. It includes a manual and drawing and a G-10 template with a gluing jig.
                • First is to clean the soot off the sheet.
ID:	39514 Click image for larger version
                  • Then the gluing jig is assembled.
                    • The fin and base are assembled and inserted into the jig. Bead of CA glue is added and repeat.
ID:	39522 Click image for larger version
ID:	39523 Click image for larger version
                      • A whole lot of them and a few spares done and stuck into cardboard for priming and paint.
                        • The drawing shows dimensions for positioning the template and it is taped into place. Then a knife and a piercing tool is used to puncture the skin. Once you have done the entire length of the template, it is removed and the individual vortex generators are glued on.
                          • The end of the template is moved over and slips over the last vortex generator and the process is repeated.
