Ok, back at it with the engine box.
Credits: Jim D. for the luggage door hinges and the top front corner of the main door additional magnets.
Kevin K. for the idea of adding a positive latch to the main door.
Jeff D. for the source of the latch mechanism (which actually was for my generator cover project)Last edited by gunny11; 02-11-2019, 05:47 PM.Gunny
Window frame extensions. 1/16" thk. ply glue into the fuselage to bring the side and top windows flush. You can go through a bucket of binder clips easily....
So i just used the glass to "clamp" those frames into place while the glue dries. Not to worry about accidentally gluing them in yet because the protective wrapping is still on. They will be glued in after the model is covered.
Tail wheels really take a beating. FWIW- consider making the portion mounted in the fuselage have its axis run through the tire contact patch. That reduces 'lever' forces in side load conditions.
I think I know what you are trying to say... It's 7/32" dia. 1095 music wire and set up as a torsion rod. I tested it on my hydraulic test bed weighing 50 lbs. There's a video of it on my web site. But not to worry, because I'll give it to Kevin K. and let him put it to the ultimate tests with his STOL Tundra type tail wheel landings,
