Update on Speed Bond...while this is great for wood pieces going together immediately, it fails when trying to do say balsa sheeting over ribs were it takes a bit of time to spread the glue..i have found it kicks too quickly and when you put those pieces together, the bond is brittle, a bit like CA. today I bumped a sheeting piece gently after assembly and had it tear open like medium CA.
I have tried to re glue areas before assembly as well...just gets gone too quickly for less than immediate assembly.
So, again, it works fantastic with say ribs onto spars or shear webs, but I would avoid using this on balsa sheeting over a built up ribs etc...
Had to re glue after sanding and using Tite Bond and water...best sheeting glue in my experience...just be patient as it will take over nite to dry..
