Carbon Cub FX-3......
    Added some reinforcing to the lower rear hatch with some carbon square "rod" that I had on hand. Then added fabric.
    Click image for larger version  Name:	IMG_6031.JPG Views:	23 Size:	116.3 KB ID:	45466 Click image for larger version  Name:	IMG_6032.JPG Views:	24 Size:	135.1 KB ID:	45468
    Click image for larger version  Name:	IMG_6033.JPG Views:	24 Size:	86.0 KB ID:	45467 Click image for larger version  Name:	IMG_6035.JPG Views:	27 Size:	115.5 KB ID:	45464
    Poly-Brush to seal the fabric. Pre-coated the center section to seal the balsa
    Click image for larger version  Name:	IMG_6036.JPG Views:	24 Size:	117.3 KB ID:	45465
      DLE-222 installation / conversion
      Mounting a "dummy" 170 template to get the prop hub position and check the cowl alignment.
      Click image for larger version  Name:	IMG_6038.JPG Views:	0 Size:	100.8 KB ID:	45482 Click image for larger version  Name:	IMG_6039.JPG Views:	0 Size:	118.8 KB ID:	45485
      Click image for larger version  Name:	IMG_6040.JPG Views:	0 Size:	119.0 KB ID:	45484 Click image for larger version  Name:	IMG_6042.JPG Views:	0 Size:	65.1 KB ID:	45480
      Click image for larger version  Name:	image_18149.jpg Views:	59 Size:	109.2 KB ID:	45481 Click image for larger version  Name:	image_18151.jpg Views:	60 Size:	56.7 KB ID:	45483
      Starting on the JIG using "tounge depressors" popsicle sticks. Hopefully it will just slide on and off.
      Click image for larger version  Name:	IMG_6047.JPG Views:	0 Size:	109.5 KB ID:	45486
        JIG to capture the prop hub location using the engine box / firewall as a reference.
        Click image for larger version  Name:	IMG_6048.JPG Views:	43 Size:	128.4 KB ID:	45507 Click image for larger version  Name:	IMG_6049.JPG Views:	43 Size:	110.3 KB ID:	45505
        The DLE-222 "Dummy" engine ( 261mm long )
        Click image for larger version  Name:	IMG_6050.JPG Views:	44 Size:	67.7 KB ID:	45508
        49 mm removed
        Click image for larger version  Name:	IMG_6051.JPG Views:	43 Size:	116.5 KB ID:	45506
          Love the simple, smart dummy engine idea. This is going to be another beautiful bird!
        Firewall installation
        4 layers of 1/8" Baltic birch glued together with Gorilla wood glue
        Outer layers are 0.90 G10 material - on the original firewall was 0.60 G10.
        Click image for larger version  Name:	IMG_6057.JPG Views:	23 Size:	77.0 KB ID:	45534 Click image for larger version  Name:	IMG_6059.JPG Views:	23 Size:	112.8 KB ID:	45537
        West Systems and 404 high strength additive for attachment. 1" triangle stock on the rear side of the firewall.
        Gravity method.
        Click image for larger version  Name:	IMG_6060.JPG Views:	23 Size:	72.1 KB ID:	45536 Click image for larger version  Name:	IMG_6064.JPG Views:	22 Size:	74.1 KB ID:	45535 Click image for larger version  Name:	IMG_6071.JPG Views:	23 Size:	62.7 KB ID:	45533
          Vertical Gravity method again for Positioning the DLE-222 "dummy"
          Click image for larger version  Name:	IMG_6073.JPG Views:	0 Size:	89.6 KB ID:	45556
          Checking to make sure things are lined up before taping it down and marking the holes.
          Click image for larger version  Name:	IMG_6079.JPG Views:	0 Size:	66.1 KB ID:	45555 Click image for larger version  Name:	IMG_6077.JPG Views:	0 Size:	81.4 KB ID:	45553 Click image for larger version  Name:	IMG_6076.JPG Views:	0 Size:	118.1 KB ID:	45560
          The rear of the DLE-222 has some Socket heads sticking out so extra holes are required - with a little fine tuning required.....aka ...Dremel tool.
          Click image for larger version  Name:	IMG_6092.JPG Views:	0 Size:	128.8 KB ID:	45557 Click image for larger version  Name:	IMG_6081.JPG Views:	0 Size:	82.0 KB ID:	45554
          Success.........
          Click image for larger version  Name:	IMG_6090.JPG Views:	0 Size:	126.6 KB ID:	45558 Click image for larger version  Name:	IMG_6089.JPG Views:	0 Size:	146.1 KB ID:	45559
          Now I can install the rotisserie mount on the front and paint the fuselage.
            Back to the wings, ...two spray coats of Poly-Brush to seal the fabric.
            Click image for larger version  Name:	IMG_6095.JPG Views:	0 Size:	154.1 KB ID:	45601
            And then the fun part , Poly-Spray UV protection and anti-model "see-thru" look.
            Click image for larger version  Name:	IMG_6096.JPG Views:	0 Size:	178.9 KB ID:	45603 Click image for larger version  Name:	IMG_6097.JPG Views:	0 Size:	170.3 KB ID:	45604 Click image for larger version  Name:	IMG_6098.JPG Views:	0 Size:	165.5 KB ID:	45602
            I have to wait 4 days for the solvents to boil off before I can spray the Aero-Thane, I put two coats of Insignia White 105 Poly-Tone to where the Omaha Orange is going to be applied.
            Click image for larger version  Name:	IMG_6103.JPG Views:	0 Size:	158.2 KB ID:	45600
            Scott
              Saw Steve P post about the DLE canisters and figured "what the heck" .......I got the DLE-170 tuned exhaust system since I'm going to be dumping two cylinders into one ( at different times thou ) I figured a little more volume would be helpful. I stuck my borescope inside to see what there and its pretty simple 2 chamber design - exhaust goes all the way to the back , exit tube goes all the way to the front with 4 rectangular punched holes partially pushed open ( one side still attached ). Kit comes the a 45 degree exit silicone line that makes positioning easy ( and anti-chaffing )
              Getting the general layout while I wait for the exhaust stubs and other items from K & S in Germany.
              K&S #506 comfort mounts as the Canisters are 75mm in diameter.
ID:	45623 Click image for larger version
                FWIW, I used Evolution cannisters. For all I know, they came from the same factory? ;-)
              • MarnochS
                MarnochS commented
                Oops, my confusion on canisters.....
              Exhaust headers....in component format...."some assembly required"
                Happy brazing! The part I like least.
              2 spray coats of Poly-Brush on the fabric area then 2 spray coats of Poly-Spray........followed by a little bit of sanding to smooth things out.
              Then 1 coat of Insignia White Poly-Tone ( where the Omaha Orange is going ).
              Now on to the front half with Primer.......
              Click image for larger version  Name:	IMG_6114.JPG Views:	0 Size:	166.6 KB ID:	45780 Click image for larger version  Name:	IMG_6118.JPG Views:	0 Size:	174.2 KB ID:	45779
                Productive Labor Day
                  As Jim Mckay use to say - the thrill of victory and the agony of defeat
                  Oops...........poor clamping technique........where did I put that buffing compound.....it's around here somewhere
                    some minor sundry stuff while sanding out all that gravel......
                    Thought the Gas Caps looked a little thick so Mr Dremel and 4 cut-off wheels thinned things out.
ID:	45886 Click image for larger version
                      Things are starting to get serious.....gluing the control horns in the Aileron.
                      Painted every thing to try to hide it as much as possible.
                        Some Motivational Assembly
                        • stevekremer
                          stevekremer commented
                          That is looking sweet!
                        Nice Job Scott
