California Smelly...yak 2
  • Needs the half eye and the black outline around the mouth. Really awesome!!! Very cool!
    • Oddly the simple things take the longest .......
ID:	39220 Click image for larger version
      • Gluing on the last 6 inches of the wing.....
        • its worth the effort Scot. Great looking plane.
          • Thanks Len......only 10% left to do.............
            Electronics integration time.....Wing wire harness
            Using Molex Microfit 3.0 10 pin -dual row locking connectors (with gold plated contacts) - max current rating is 8.5 amps.
            Just have to be careful when swagging to leave the vertical tabs standing as they align in the connector.
ID:	39267 Click image for larger version
ID:	39266 Click image for larger version
            On the Fuselage side used the panel mount style and fabricated an attach plate using 0.080 G10 material
ID:	39268 Click image for larger version
            Links to the connectors and pins
            Panel mount - fuselage side
            Gold plated pins for fuselage side
            Wing
            Gold plated contacts pins for Wing side
            Fabricated my EYE using monokote white trim sheet and black and red sign vinyl - just in case I want to change it in the future.
            Has that "painted in the field" look
              Outstanding! Love it...
          • Programming......... Holy-time warp Batman..........have I really been "playing" with this for 3 hours......
            and the associated wiring spaghetti that ensues
            And of course an Eye Candy shot down the "busty innards"
              I see some 2-33 parts in there too! LOL
            • MarnochS
              MarnochS commented
              no good Idea goes unused
          • Fun..... isn't it?
            • Finally worked up the courage to separate the cowl from the fuselage......
              Started out scoring the seam line to try to keep the paint from pealing up.
              Click image for larger version  Name:	IMG_5450.JPG Views:	0 Size:	60.0 KB ID:	39416 Click image for larger version
              Click image for larger version  Name:	IMG_5454.JPG Views:	0 Size:	121.4 KB ID:	39411 Click image for larger version  Name:	IMG_5455.JPG Views:	0 Size:	31.3 KB ID:	39409
              The Stare down....but my Inspector seems unconcerned.
              Click image for larger version  Name:	IMG_5462.JPG Views:	0 Size:	85.1 KB ID:	39410
              DA150 mounting and cutting the canister stacks
              Click image for larger version  Name:	IMG_5461.JPG Views:	0 Size:	107.4 KB ID:	39413 Click image for larger version  Name:	IMG_5463.JPG Views:	0 Size:	111.8 KB ID:	39412
              • On the practical side of moving around a Fuselage without landing gear.....the Bidule 170 seemed like a good reference point. I think I'll be able to tip it back and install the wings.......
                Apparently I have a big animal in the yard.......looking my way......
                • Originally posted by MarnochS View Post
                  Pacifica? New work vehicle?
                  Rick Shelby
                  Team Horizon
                  • MarnochS
                    MarnochS commented
                    Almost........its a value-orientated Chrysler Voyager 2020 that I'm playing host to for a couple of months. Its a great storage area for the Cmelak Wings.
                • Scott,
                  Why did you choose the MTW 120K? 150cc divided by two is 75. So why not the MTW 75K or the 80K?
                  • MarnochS
                    MarnochS commented
                    Hi Steve,
                    The 120k are less restrictive on the exhaust flow and they are the one's DA recommends ( in the short version ) for the 150/170.
                    On the MTW website the 80K is listed for cylinders 50 - 62ccm (max) while the 120k is for 70 - 95ccm.
                  • stevekremer
                    stevekremer commented
                    Thanks Scott
                • Easy mobility now
ID:	39449 Click image for larger version
                  I'll have to test wing installation and see if I got the correct height..
                  The 120K canister installation
                  • Great Scott!! Dual use landing gear, tricycle and tail dragger at the same time. Looks good Scott.
                    • Fenders.......
                      Got the basic shape and made a pattern to "try" to reproduce the six needed,
ID:	39563 Click image for larger version
ID:	39560 Click image for larger version
                      • is this a glider tow or a scale master project.. isnt winter fun
                        • MarnochS
                          MarnochS commented
                          Trying to to keep the early morning towing Grass / Mud off the bottom of my pretty wings.......the Bidule170 gets some great racing stripes.
