California Bidules
    Thanks Stew,
    I was looking around and found those thru HobbyKing......Decided to go with Hangar 9 10-32 Swivel Clevis Horn instead. Main reason is their little bit better quality and fit.
    Fun with the Cowl....
ID:	6677 Click image for larger version
ID:	6676 Click image for larger version
    Using transparent overhead projector sheets to transfer the mounting holes / engine cylinders
ID:	6680 Click image for larger version
ID:	6679 Click image for larger version
    now just have to build up the courage to start cutting....
      Ohhhhh
      Been there!!!
        Zonal saw Anxiety overcome........plus I have some "Omaha" orange paint for ....."corrections"
        Going for the stepped approach to keep things lined up...cut and installed the rear overlap .. then moving on to the front
ID:	6901 Click image for larger version
ID:	6903 Click image for larger version
        Scott
          Good idea using a step approach, never really thought about that!! Hmm. gotta remember that one.
            Really happy with the result on the forward cowl sections
ID:	7322 Click image for larger version
            Bolted the DA170 back on the fuselage and checked the fit....and started with the exhaust system. I decided on the "functional" approach to removing the cowl and cut slots. I think eventually I'll probably make some covers to go over the pipes on the cowl. I did add a 5.7oz carbon cloth to the bottom of the cowl to stiffen it up.
ID:	7324 Click image for larger version
ID:	7326 Click image for larger version
              Excellent job Scott.
              I agonized over that same issue. In the end, I cut holes, but every time I have to pull off the cowl, I kick myself.
                Moving on to the wing / flap modification for top driven flaps for 70-80 degrees deflection ( 145mm travel ) and 180 degrees of servo travel ( to reduce servo current when the flaps are down )
                First thing is the mock-up ....to see if things will fit (the mock-up got epoxied from the DG600 horizontal stab fiberglassing)
ID:	7982 Click image for larger version
ID:	8000 Click image for larger version
                Using 0.080 G10 material for the attachment point
ID:	7988 Click image for larger version
ID:	7990 Click image for larger version
                Then lining thing up and ....cutting
ID:	7992 Click image for larger version
                  I'm committed now
                  found there was a former supporting the original servo mount....so......
ID:	8096 Click image for larger version
                    More Flap servo installation progress
                    0.100 G10 for the cover, 4-40 button head stainless screws to attach everything
                    Button head screws weren't long enough to use a standard lock nut so I improvised by glueing T-nuts to the plate
ID:	8141 Click image for larger version
ID:	8140 Click image for larger version
                    Checking on how things line up
                      Control Surface Actuators
                      For the Aileron servo connection I used Hanger 9 10-32 Swivel Clevis horns (HAN3615) utilizing the threaded rod. I just threaded/glue it in from the bottom side. As you can see there's some filler at the base. Since I didn't want to look at the threaded rod, I found some thin wall Carbon tube ( 0.235 od/ 0.190 id.), Same for the servo pushrod ( 0.180 od. / 0.109 id) although I did have to run a small round file thru the center to get the 3mm threaded rod to fit.
                      Flap push rods consist of 8-32 thread rod glued into Carbon tubes ( 0.250 od / 0.154 id ) then the 4mm Traxxas Ball links are threaded on. Also a sequence of getting the pushrod length close
ID:	8240 Click image for larger version
ID:	8242 Click image for larger version
                      I using Horizon Dynamite DYN2561 Aluminum servo horns as they have a 15mm position which give me the correct throw for 70 degrees (130mm) of flap
                      The Hitec arms 20 mm gave a 90 degree flap which I may try later on.
ID:	8245 Click image for larger version
                        Nice work Scott!
                        Everytime I look at this thread I think of a line in that great Eagles song.... "Working on the Bidule California"
                          Thanks Pete.....well.... technically I live on a desert highway ....and burrrr.....there's a cool wind.....it must be down to 65 or something.......
                          And of course, ....the gratuitous flap actuation video......
                          The BoomaRC master and ignition switches a nicely hidden by the blue stripe.
                          Scott
                            Bidule Brakes........
                            Well I got my super cool Aviation Concepts brakes in and attempted to order the Aeroworks 8.25" wheels......but found out that they are" out of stock" for an indefinite time frame.
                            Plan B....
                            going to have to manufacture an a disc rotor adapter for the MBS off road skateboard wheels. In the research process I found some really cool carbon rotors......super Bling....
                            Have a set of 200x75 tires on order as the current 200x50 are a little small for the main wheels.
ID:	8986 Click image for larger version
                            I saw a photo of one of Len's High Alpha landings and figured I needed a tail skid.......had some 5.7 oz. Kevlar cloth....so....
                              Hi Scott,
                              Super looking rotor bling!!
                              Like the tail skid also, nice touch.
                                Thanks Len,
                                Moving on to the Servo Lead "Wrangling" step of the fuselage, I'm using 5/8' wing sockets from TNT cut down a little more than half. (5/8?)
                                Glued on with Tightbond3
ID:	9070 Click image for larger version
ID:	9071 Click image for larger version
                                Scott
