All of the shear webbing has been installed! Whoopee! That was a bit of a boring job. I was going to actuate the ailerons via a torque rod with cranks to drive cables to the aileron horns but there isn't enough room for the outboard cranks inside the 'D' box portion of the wing. The ailerons have two set of horns connected to cables. One is only 3 ribs over from the outer panel root end and the other is 11 ribs out. So... pulleys and cables will be used... just like full scale! Waddayaknow! A lot of time was spent running dummy cables to get the lead outs or ferrules installed. 1" diameter pulleys were used. The outer aileron horns have pulleys stacked one above the other and the inboard ones have them separated. The last two pics not only show the inner end pulleys but the outer ferrules pre- and post- installation. More stuff has to be done but I spent a lot of time on these little details!
More to come!
More to come!
