California Smelly...yak 2
  • #61
    That gear is totally sweet!
    • MarnochS
      MarnochS commented
      It's super plush on the initial part of the stroke too.......going to be like landing on a couch.
      Where's that beer?
  • #62
    Mounting the Gear leg sockets......
    Looking at the 3-view and pictures, the wheel axle looks to be even with the leading edge of the wing.
    Click image for larger version  Name:	GearAxels.JPG Views:	1 Size:	45.0 KB ID:	34254Click image for larger version  Name:	GearAxels2.JPG Views:	1 Size:	49.4 KB ID:	34255
    Finally settled on the gravity method to hold the gear leg in place, also since the leg has about 7 degrees of forward sweep, I opted to angle the bottom mounting plate and back-fill with WestSystem epoxy/404 filler. I placed three 0.130 shims on the back of the mounting plate to get the correct angle
    Click image for larger version  Name:	IMG_4867.JPG Views:	1 Size:	119.0 KB ID:	34256 Click image for larger version  Name:	image_13318.jpg Views:	1 Size:	91.2 KB ID:	34260
    ....the inside is never pretty .....
    Click image for larger version  Name:	IMG_4872.JPG Views:	1 Size:	58.8 KB ID:	34262
    Click image for larger version  Name:	26431785798_f534177040_b.jpg Views:	1 Size:	126.4 KB ID:	34263
    • #63
      Long legs....and some hanger flying.....
      Click image for larger version  Name:	IMG_4873.JPG Views:	1 Size:	84.3 KB ID:	34299 Click image for larger version
Name:	on the stand.JPG
      • #64
        continuing on with the gear leg installation. Recessing the pieces into the balsa.
ID:	34615Click image for larger version
ID:	34619Click image for larger version
ID:	34616Click image for larger version
ID:	34617Click image for larger version
        • #65
          Do you have a way to adjust the gear in case it wants to nose-over too readily?
          • #66
            No Adjustments,.....in for a penny ... in for a pound ....as the saying goes. the wheels should be just behind the leading edge of the the wing ....which should be pretty stable
            Finishing up on the right center section.
            • #67
              Getting closer to the wing tips.....clamp-O-rama
ID:	34933Click image for larger version
              • #68
                And more clamps.......Was a bit paranoid about inducing any twist into the wing while attaching the lower D-box skin so I decided on the "gravity method again.......small wedges on each rib to push the skin up.
                Click image for larger version  Name:	IMG_4900.JPG Views:	1 Size:	107.5 KB ID:	35098
                Attaching the Trailing edge stock.....I'm running the flaps to Rib#7 ( 2 more bays ) to give the wing a 60/40 split ( flap/aileron ) and since I'm going to have winglets the ailerons will be more effective at the tip ( at least that's what I'm telling myself )
                Click image for larger version  Name:	IMG_4901.JPG Views:	2 Size:	128.1 KB ID:	35100
                • #69
                  Outer Flaps and Aileron. Staying with the bottom hinge setup on the outter flap . Drilling the hinge holes I thought was going to be a bit challenging , but turned out not to be a big deal.
                  Using the handle end of the 3/16 round file ( sharpened up a little ) does a great job of drilling matched holes.
                  Click image for larger version  Name:	IMG_4905.JPG Views:	1 Size:	94.8 KB ID:	35222
                  Built the flap and aileron against trailing edge of the wing for a better match, using 0.060 shims in between the surfaces for spacers. And a jig at the wing tip for a matched aileron tip for minimal sanding.
                  Click image for larger version  Name:	IMG_4906.JPG Views:	2 Size:	94.0 KB ID:	35226Click image for larger version  Name:	IMG_4908.JPG Views:	1 Size:	107.5 KB ID:	35227
                  Top hinging the aileron for a smoother look
                  Click image for larger version  Name:	IMG_4909.JPG Views:	1 Size:	63.8 KB ID:	35224Click image for larger version  Name:	IMG_4910.JPG Views:	1 Size:	52.8 KB ID:	35225
                  Time to work on the Winglets........
                  • #70
                    Mockup Winglet to check sizing and shape. The TL90 digital pitch gauge makes it easy to get the right angles.
ID:	35234Click image for larger version
                    Using construction paper and 1/8" sq balsa to reinforce.
ID:	35233Click image for larger version
                    • #71
                      Looking awesome Obi Wan!
                        +1 I hope it is ready for Horizon!
                    • #72
                      Plugging away .....Horizon....definitely a... maybe.....
                      Flaps - bottom hinged, top actuated and 55 degrees. Outer flap goes to Rib 7. Estes 1/2" rocket tubes for servo wire containers.
ID:	35766Click image for larger version
                        Whoo that's a nice looking wing. Love the flap extension.
                    • #73
                      Thanks Gunny,
                      Winglet fun....going to make a plug/mold for the winglets from blue foam so Hotwire templates ( Formica ) were made and stuff was cut.
ID:	35772Click image for larger version
ID:	35773Click image for larger version
                      Using PSU 94-097 winglet airfoil
ID:	35779Click image for larger version
ID:	35777Click image for larger version
                      Since I was over zealous sanding the cut ridges and sanded off the top trailing edge, fiberglassing it so I won't put too many dents in it.
                      • #74
                        Foam shaping to fit the winglet.....
ID:	35787Click image for larger version
ID:	35788Click image for larger version
                        • #75
                          Starting to look presentable.....
ID:	35800Click image for larger version
ID:	35799Click image for larger version
                            Oh yeah...baby!
                          • Mosquito
                            Mosquito commented
                            Settle down Michael.......
