Rosenthal ASW-28 1/3 scale
  • Rosenthal ASW-28 1/3 scale
    Ever since seeing the photo of Jurgen Mayer making a low inverted pass with his 1/3 scale Rosenthal ASW-28 at the Memaloose airstrip in Idaho, I was hooked (circa 2002-Sailplane&Electric Modeler)
    Well, I'm finally getting going on it. When I ordered it from the previous ower of Rosenthal, Philippe Stampf, he had the 5/6m carbon knuckle hinge wing in stock, how could I say no....
    Of course now its even easier ordering a Rosenthal Sailplane as Bruce DeVisser has started importing them.
    All of the flying surfaces are being glassed with 0.5 oz. cloth and then painted
    Scott
    First order of business was to build a storage box to protect it from the hanger rash gremlins that so often infest my garage (and Van)
    Started on the 5m tips, Stabilizer and Rudder glassing them with 0.56 oz cloth from thayercraft.com (104) and West Systems Epoxy.
ID:	3852 Click image for larger version
ID:	3853 Click image for larger version
    Scott
    • French1
      French1 commented
      Very nice storage box scott!
    Congratulations Scott,
    Watching with interest!
      I have my Fire destroyed replacement Pilatus B4 arriving this week, thank's to Bruce!
        Scott, I have to say that the Memaloose airstrip is not in Idaho, but Oregon. You can look out over Hell's Canyon and see Idaho, but you are standing in Oregon. I was fortunate enough to be there the day that photo was taken, and have flown out over the canyon many times. From the airstrip to the canyon floor is about 4500 feet nearly straight down, and when the air in the canyon heats up a bit from the morning sun, the lift is just incredible. The Snake River is in the bottom of the canyon, and Idaho on the east side of the canyon. Fun times! Wil Byers still holds the event nearly every year, so come on up to Joseph, Oregon, and a side trip to Memaloose airstrip and fire lookout tower.
        That said, the ASW-28 is a great flying glider in most any scale, the bigger, the better. I believe Rosenthal used to make a 1:2.5 machine that is wonderful to fly--at the Memaloose, or anywhere else.
        Larry Fitch
          Hi Larry,
          Thanks for the clarification, I guess I'm showing my bias toward Idaho over Oregon.......
          Started in on the wings......and yes, my hanger does show remnants of the 80's
ID:	3959 Click image for larger version
          Scott
            Ran in to a minor issue when I was smoothing the top surface of the left wing..... the center of the spoiler area skin wasn't stable and had lifted a little. So out came the 10cc syringe and a CA tip to get the epoxy up underneath the skin.
ID:	6883 Click image for larger version
            Then on to the 0.75 oz fiberglass to the top of the wing and the second flow coat to fill the weave.
ID:	6886 Click image for larger version
              Good catch. Hopefully thats the only area!!
                Many Thanks to Asher Carmichael for his excellent cockpit fiberglass "kit'.
                In this case consisting of seat pan, back, headrest and side comb moldings. Excellent fit in the Rosenthal 28 fuselage.
ID:	6890 Click image for larger version
ID:	6891 Click image for larger version
ID:	6892 Click image for larger version
ID:	6893 Click image for larger version
                I came expertly packaged to avoid shipping "rash"
                A nice extra was the cover letter and notes on AS /W /H /Gxx molded parts finishing recommendations Photos of full size cockpit layouts too
ID:	6897 Click image for larger version
ID:	6896 Click image for larger version
                My Graupner / Tangent ASG29 is going to need a little trimming - i bought a second cockpit set to it too.....
                Contact Asher Carmichael if your in need of one.......
                Scott
                • Freeflight
                  Freeflight commented
                  Where can it get one of those kits ( how much), thinking of redoing my cockpit on my 23 years old 1/3 ASW 20.
                  Gunnar
                Do you have a particular sailplane 'N' number that you'll copy or will it be spurious?
                  Nothing in mind at present....so I guess it will be Spurious when it happens.........
                  Scott
