Ended up not having to work today! Since the big airplane is broken, the little airplanes get some love.
The first step in the manual is to cut holes in the root of the tip for your servo extensions, luckily this is already done, as you can see in previous photos.
Started off setting up the servo mounts for the ailerons in the wing tips. The manual has you place the servo on the mount and cut away enough of the mount to clear the servo arm.
Next step was to install the servo to the mount. Ran into an issue here. The screws that come with the servo are too small and drop right through the hole in the servo mount. A standard servo screw will not fit through the screw slots in the servo. Will have to source some different screws to install the servo.
This prevented me from finishing the servo install, so instead I installed the aileron horns, built some extensions for the aileron servos and glued in the anti rotation pins.
