Another T45 Swallow - Slingsby --
    Nice cockpit paint! Perfect... Good work
      Thanks Gunny,
      While I wait for the Cockpit paint to cure, a splash of Red for the wings....I'll have to put the spoiler caps on eventually.
      Glued on the Aileron and connected the servo ( trimmed the servo horn and a little yellow shrink tubing to hide the threads. )
        Nice touch!
      • Gene C
        Gene C commented
        Second that! What about weight gain? (Ha,Ha) but whats the flying weight now?
      • MarnochS
        MarnochS commented
        That the $64 question.......Probably on the higher end of the range I would guess.
        Getting closer to the "nose weight" portion of the program.
      Danger Will Robinson, Danger........Canopy installation........
      After a minor comment from Jim......I put some blue tape on the front of the canopy with an Arrow.......
      Electronics integration completed so the Rudder tray was installed.
        The moment of Truth - accompanied by some ZAP Formula 560 canopy glue.
        Now the interesting thing will be to get the orange clamp off....
        • Gene C
          Gene C commented
          Interesting situation? but I believe you can pull it off.
          You could have attached a thread to the clamp first and run it out through the tow release opening so you could just pull on it, or just put your hand through the wheel opening!
        • MarnochS
          MarnochS commented
          Got the clamp off,....combination of micro flyer pushrod with a Z-bend as the clamp has a small hole drilled in the arms .....and a carbon rod.
          Of course this is after I got the canopy unglued from the airframe.
        Put things together to start the balancing process......and see how things look with the Canopy on and Spoilers up.
          Oh boy... isn't that pretty! I betcha can't wait to fly it! Did 'Inspector Cat' approve?
            Beautiful !
              trim on the canopy.......
ID:	30463Click image for larger version
                And it fly's.......quit wonderfully I might add, excels at working the smallest thermal bubbles, very nimble
                Balance is at 7 inches back from the leading edge root.
Name:	A Swallow and its Pilot.JPG
ID:	32649Click image for larger version
                Trifecta of fun .....Swallow, Bidule, and Traeger BBQ ( saturday nite BBQ - smoked Ribs and then fresh baked cookies )
                • Gene C
                  Gene C commented
                  Outstanding Scott, and that includes the cookies.
                how funny i'd have taken a photo of this........
                • MarnochS
                  MarnochS commented
                  Probably the wonderful aroma of Hickory smoke wafting through the flight line.......
                Absolutely beautiful and inspiring. Thank you!
