Today was a good day! Very good because somebody just made it into the paint booth!
Modellbau Hans Muller 7-meter Salto Restoration
We contracted with the same workshop quality assurance firm as Jim Dolly uses. The white paint inspector approves!
1 PhotoTeam PowerBox Systems Americas... If flying were the language of men, soaring would be its poetry.
The radio location/setup in this bird always had me a bit baffled. Winter Workshop sez time to do away with this and do something better.
Not sure if owner A or owner B did the dual 6V big honkin’ NiCad battery rig, but owner C (me) when over to smaller 5000 NiMh 5 cell packs years ago. Today the packs are headed to recycling and the frames were binned. The rails inside the fuselage that marry to the frames were carefully chiseled out.
7.4V dual PowerPaks will be regulated to 5.9V which will be much easier/consistent on the servos.
With the lean mean PowerPaks in the same locations, I needed to add 26 ounces of lead shot and epoxy to the nose!
Last edited by Steve P; 01-16-2022, 12:39 AM.Team PowerBox Systems Americas... If flying were the language of men, soaring would be its poetry.
No more sideways radio installation. Cleaned up the vertical mount a bit and went in a different direction— horizontal.
The new electrons fit well. A bit of touch-up from pulling all the other stuff out, not pretty but effective.
2 PhotosTeam PowerBox Systems Americas... If flying were the language of men, soaring would be its poetry.
