Aviation Concepts 1/3-scale Schweizer 2-33 ~ Build Thread by JimD
    Hey Scott, thanks for keeping the home fires burning while I was away! We made a little 3,286 mile trip over the last eleven days.Covered eleven states along the way and got to see a lot of Texas!
    One of the fun things you get to do when building the 2-33 (both sizes) is to silver solder metal parts together for the strut attachments. The metal straps have three holes and do make note that the center hole is closer to one side than the other!
    Click image for larger version  Name:	144.JPG Views:	1 Size:	260.4 KB ID:	15003
    Click image for larger version  Name:	145.JPG Views:	1 Size:	214.8 KB ID:	15000
    Click image for larger version  Name:	146.JPG Views:	1 Size:	301.6 KB ID:	15001
    Click image for larger version  Name:	147.JPG Views:	1 Size:	326.4 KB ID:	15002
    Now...if you were paying attention, you noted that I soldered the nut to the wrong end of the metal strap...like I said, note that the center hole is closer to one side than the other! Oh well, just solder a nut to the other end and then removed the incorrectly attached one.
    Click image for larger version  Name:	148.JPG Views:	1 Size:	340.9 KB ID:	14998
    Click image for larger version  Name:	149.JPG Views:	1 Size:	239.7 KB ID:	14999
      Fuselage taking shape - quality and detail of the plywood cut parts is outstanding.
      I Spar Varnished the top cabin pieces and ornament first thing before I got "finger prints' all over them
ID:	15070Click image for larger version
        Great Scot........
        Had to do that. You're cruising now, keep the foot on the pedal as the Horizon event is on the Horizon..... Oh man, I'm on a roll
        Are you going to Visalia or Coachella?
        • MarnochS
          MarnochS commented
          Hi Len,
          I going to both Coachella and Visalia. Coachella has a paved runway and I'm itching to test my Bidule and its brakes ......
        Clamps....and more clamps.....stringers
        My wing strut hardware was looking a little sad (oxidization) so a little clean up and some primer
        And cross member installation
          Okay Scot, now you're pushing me!
          Added stringers to the aft fuselage so we could do more work on the fin and stab mount.
            Decided to go with 1/8" pin hinges across the tail ......surfaces rounded and ready to cover.....which I covered the elevator servo access cover ..Stits lite.
            Click image for larger version  Name:	IMG_3938.JPG Views:	1 Size:	74.5 KB ID:	15183Click image for larger version  Name:	IMG_3937.JPG Views:	1 Size:	40.2 KB ID:	15182
            And a little more covering
              We are going to use the Ohio Super Star tail wheel option, so we added a hardwood block as per the plans Gunny provides for this.
              Checking fit of bottom access hatch.
                Now it's time to go back up front and work on the stringers and rudder servo mount. Bricks and clamps plus rubber bands all come in handy!
                  Looking Good Jim.....I've gotten side tracked into covering my Stab/Elevator
                  I think I'll mount the haigh style tail wheel so we can match.....
                  Click image for larger version  Name:	IMG_3943.JPG Views:	1 Size:	87.4 KB ID:	15217 Click image for larger version
                    I sure am enjoying watching you and Scott building almost stereo Schweizers!
                      Thanks Mike, this is pretty fun.....
                      Moving on to the Keel ....
ID:	15324Click image for larger version
                        1/2" triangles around the wheel box
                        Plans call for #2 counter-sunk screws to reinforce the lamination for the scale tow release retrofit ...I opted for 0.080 carbon rod epoxied in place (sanded flush)
                        Poly-Spray on the Stab/Elevator
                          While the fuselage is still sitting flat on the bench, I thought it would be a good time to work on some interior details like seats and side panels. Click image for larger version  Name:	167.JPG Views:	1 Size:	249.8 KB ID:	15353
                          Click image for larger version  Name:	168.JPG Views:	1 Size:	250.6 KB ID:	15354
                          Click image for larger version  Name:	169.JPG Views:	1 Size:	286.9 KB ID:	15357
                          Click image for larger version  Name:	172.JPG Views:	1 Size:	306.3 KB ID:	15358
                            Wow Scott! That tail assembly looks AWSOME!
                            Keep up the great work.....
                            Jim, your slacking behind, LOL
                            Somthing to get you guys inspired....
                            I'm Back.......... lol
                              Jim, can I borrow your seat templates.....very nice
                              Box of Paint arrived ....At least I know what color is in each can...........now if it would just stop raining......
                                Hi Scot, just PM your mailing address and I will send the templates.
