First I used the heat gun and mitten to smooth out all the wrinkles.
The next issue was the well documented problem of the flap being hinged on top instead of the bottom.
I cut them loose and flipped them over and discovered that they really needed some wood added to the leading edge. So I stripped them down and glued on some scrap balsa and recovered them.
I'm taking Len's advice and going with Hitec servos instead of the el cheapos. I found that by enlarging the openings HS-82MGs will fit in the aileron bay and HS-225MGs will work for the flaps. I started by adding some 1/8" plywood to the servo bay to raise the servo and reinforce the structure.
Then glued in some mounting blocks and used some G10 straps to secure the servos. I used the supplied servo covers.
The canopy is next.
The canopy is next.
