Hello all, new to this forum. I am about to purchase a Hngr 9 Pawnee, but it does not have a tow mechanism. Where would I purchase one?
H9 33% Pawnee Tug Conversion
 You need something like this. http://www.icare-icarus.com/Remote-t...ne_p_1230.html
 Need to add a bulkhead and use a decent metal gear servo.Team PowerBox Systems Americas... If flying were the language of men, soaring would be its poetry.
 I have just acquired a Pawnee, the upper L/G support bolts bent and I have replaced them with 5mm bolts and added 3/16 ply reinforcement to the box. The tires crumbled and I have added new wheels. My problem is "slack" in the support tubes where the springs fit. I can lift up the L/G about half an inch before the spring come into action. Does anyone know the size of replacement springs from McMasters? I can make a video if this is not clear
 That's in this other Pawnee thread..Originally posted by gradiz17 View PostI have just acquired a Pawnee, the upper L/G support bolts bent and I have replaced them with 5mm bolts and added 3/16 ply reinforcement to the box. The tires crumbled and I have added new wheels. My problem is "slack" in the support tubes where the springs fit. I can lift up the L/G about half an inch before the spring come into action. Does anyone know the size of replacement springs from McMasters? I can make a video if this is not clear
 My tired old Pawnee (I'm the 3rd owner) lost the right door the other day. Almost finished fabricating a new slightly more reinforced replacement but was wondering if I should duplicate the stock locking mechanism or is there a better solution? I plan on taping both doors in the future. At least the leading edges.2 Photos
 If I had a dine for everyone of those doors people have lost........... well, Id probably have a couple buck, but regardless I've heard that happens a lot. anything you can do to make it better is good, tape it for sure.Len Buffinton
