Kevin K's Aviation Concepts Cessna 185 Build
    Rudder servo mount installed and tail cone assembled.
      Tail cone installed, motor box built.
        If you need Ultracote and matching Paint for the Cowl, let me know!
          Motor box glued in and reinforced with triangle stock. Then added the sticks for the top deck sheeting.
            Tail cone sanded and shaped, instrument panel installed.
              Test fit the fuel tank platform, it didn't clear the winder. Luckily the tank still fit when I shortened it. Plus a little more carbon fiber vinyl. I really love how it looks.
                Got the doors installed, I was concerned this was going to be finicky to get everything to line up. I should have known better, everything just seemed to fall into place.
                  Using the windows to glue in the window frames.
                    Added the fuselage truss bracing and the scale steps. At this point I'm as far as I can get on the fuse without Gunny's updated windshield installation and the engine. The plan is to install the windshield when we go to Cumberland in March. So now I jump ahead to the fin and rudder.
                      Fin and Rudder
                        Finished sheeting and added the balsa leading and trailing edges, time to carve and sand to shape again.
                          Started on the stab and elevator
                            Cumberland?
                          Sorry for the lack of updates, it's been a crazy month. But, during that time we went to the Spring Cumberland event. Met up with Gunny and we worked on a better way to install the windshield. This will be reflected in the next generation of kits. The plan is to add some tabs to the top panel and include laser drilled holes to get the windshield alignment correct at the top. We found if we were off by even 1/64th of an inch, it didnt fit correctly. We also changed the cockpit sheeting to plywood over balsa instead of just balsa. Gives a better bite for the screws and is less likely to be sanded too much or too little.
                          Still needs a little trimming, but wow it looks great! Big thanks to Gunny, Len B, Steve K and Jim D for helping get over this hurdle.
                            Working on the top sheeting for the stabs and elevators
                              Interesting use of batteries!!
