Here are some pictures of the reinforcements and modifications:
This shows the hardwood corner block I installed on the fuselage side plate to the firewall. I drilled out holes and recessed them also for the blind nuts that are for the cowl bolts. There is another block on the left side as well. West Systems resin was used here and cured overnight.
On the tail section I put an L of 2 pieces of 3/8" aircraft ply forward near were the pins go in the front. One plate is flat and just underneath the stab saddle, the other plate is vertical under the first plate forming an L so it is glued to both the saddle as well as the bulkhead.
In the rear of the saddle another piece of 3/8" aircraft ply was used as a plate under the saddle. On top of the plate between the saddle resin with microfiber filler was added for reinforcement.
This was also installed with West Systems and cured overnight. The result is a very solid mounting surface for the stab now that isn't prone to vibration or twisting.
