If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You may have to register
before you can post: click the register link above to proceed. To start viewing messages,
select the forum that you want to visit from the selection below.
i find that after using the color paint i wait a few days and clear coat it to bring the shine up to that of covering if needed. helps to seal it more from fuel also..looks great and will fly soon.. i got my battery box in the skylark enlarged for 5000ma smart pack use. should help with motor run time. older eflite 4000ma ones were weak and 30c small sized but the same weight as the newer 30c 5000ma smart pack...
Here's the story with the Swiss Pawnee. I bought it from Steve P, flew it at a couple events before snagging the tow line on a tree at Windy Ridge. Wings aren't bad, but the fuse was destroyed. Jeremy and I managed to track down a replacement fuse from Horizon. So here it is, going back together. First up is to repair the wings.
