Dustin's Telemaster 40 tow release modification
  • Dustin's Telemaster 40 tow release modification
    Don't worry, the Skylark project is still very much alive! I was recently visioning flying my brand new, beautiful Skylark and having a wonderful time. Then I had a vision of aerotowing it for the first time and my vision turned into a nightmare. I don't have much experience aerotowing, so my nightmare is catching a wingtip with the first aerotow of the Skylark and destroying it. I decided I need to cut my aerotowing teeth on airplanes I care less about.
    Step 1. Get a tow plane.
    I already fly a Telemaster 40. It's been on my list of things to do to put a tow release in it, so that's what I've done. I looked at the other threads about towing with a Telemaster 40 and came up with a plan for my tow release. It's a different from the other installs I've seen. Other installs have the tow release servo installed near the CG and using a bell crank. My Telemaster 40 is powered by an OS 56 Four Stroke, so the servo rails near the CG are full (throttle, elevator, rudder). Now, I already have the battery and receiver as far aft as possible to balance the airplane, so I don't think it will be a big deal installing the tow release servo behind the CG. I can just move my battery/receiver forward and still get things to balance. So that's what I've done.
    Click image for larger version  Name:	IMG_1336.JPG Views:	0 Size:	62.2 KB ID:	41544
    Don't pass up on consulting the doctor... He's walked this path in great detail! Have a blast, it is incredibly satisfying when your flights have a purpose and supply a service.
      You're absolutely right. All plans were doctor approved.
      Here is the finished modification. Stay tuned for step 2, build a Sig Riser .
