I'm back to work on the Carbon Cub. I haven't had a chance to work on it for the past week or so with the new job.
I have all the parts all set for installing the headers and canisters. The ply plates that are part of the kit are designed for smaller canisters than will be used. I have the 70mm plates that I am modifying to install the larger canisters for the DA 150.
There are a couple ways I can do this.......probably the easiest is to use the single canister ply plates and cut them down slightly on both sides, then install staggered on formers in the area where the exhaust system goes through inside the fuselage. One plate would be on the front of the former on the right side and the other plate will be on the back of the former on the left side. A bit of slow setting resin to keep them in place and it should make for an excellent way of holding the pair of canisters in place.
I'll use 2 mounts per canister to keep things from moving around or causing a break in the headers (hopefully !).
I have both front and rear dump MTW 110 canisters along with 70mm and 90mm drop flex headers. Right now it looks like the 90mm drop flex headers with the front dump canisters will be the best fit.
A little trial and error and I'll have a better idea of what seems to work best.
Photos and more details tomorrow after I get things sorted.
