AMR Payload Master 100 / Icarus2
    WOW ....it's been a while......
    Fiberglassing the front half and then Stits lite on the back half.
  • kjkavaney
    Super Cool Scott....look forward to more build details as it happens...
    started a topic AMR Payload Master 100 / Icarus2
    Finally getting "back in the saddle: on the AMR Payload Master construction after an extended pause.......
    Progress so far......converted the flaps to top driven 180 degree servo movement .... an effort to keep the flaps up when the power is off and lower current requirements when down
ID:	11674 Click image for larger version
ID:	11675 Click image for larger version
    Got stuck on the firewall forward section - was going to put a DA150 ....but found out the size of the engine was incompatible with my cowl.
    So I opted for a DA120 that was smaller than the MVVS 116 that was in my old one.......Then, because of the Bidule170 build, I found a DA170 would fit in the cowl (with some minor adjustment)
    Here is the DA 120 vs DA170 in the Cowl
ID:	11677 Click image for larger version
    And of course some sundry Items.
ID:	11679 Click image for larger version
