First a bit about the full scale Schempp-Hirth Quintus, single-seat 23-meter open-class sailplane... The Quintus is the follow-up to the Antares (Lange) done as a joint venture between the two companies that reportedly went bad with only a handful produced -- as I understand it. They share a common wing design with the inner section developed by Lange. Here's the Quintus promo sheet: https://www.schempp-hirth.com/filead...intus_M_EN.pdf
I absolutely love the EMS Duo pure glider and my EMS Arcus with a 12S EDF. While I had eyed the new Quintus, I would have wanted it fully loaded with carbon Dbox and other additions, all the options and then shipped to the USA -- all a bit too far given my workshop is already full. Then I saw that Bruce at Rosenthal USA had one going at a super clearance price to make room for his own incoming inventory. I pounced! Then I put my Paritech Nimbus 4D up for sale and it quickly found a new home in California. Funds secured, marriage saved. Bruce delivered the Qunitus at Cumberland Summer Soar. Can't beat that!
DETAILS
- It's 6.1 meters for a scale of 1:3.75. It has a new airfoil called Aerotech M23108G wherein Ralf at EMS claims a wider dynamic speed range, better thermaling, and higher glide speeds. This is the AQX GT-R version which basically stands for built like a brick $#!+house: full CFRP + CFRP D-Box wing with cross-linked CFRP; it's very strong for extreme performance.
- Sports a fiberglass and carbon fuselage; the hollow-molded 4-piece wings (plus winglets) and tail; wings have the monoblock retention system; 4 servos per wing half (F, S, A and A). Best of all, the wings came fully pre-wired for all the servos and lighting leading to a single fuselage-to-wing plug, and Bruce also had a TEK probe mount and tubing installed for GPS triangle (damn, I can hear Stephane and Len now).
- The sailplane has a nice fully finished cockpit, detailed instrument panel, removable seat pan, canopy lock/release (dual locks on each side), the canopy swings upward on a super-strong carbon mount that locks up with a magnet, a typical retract setup with brake installed. A full fuselage bag and wing bag were included.
- LED lighting is via disc strobes in the wing bottom servo covers — each disc having nine 5-watt LEDs — and LED strobe bar built inside the fin that feeds a three clear posts in the vertical stab leading edge. The system is completely preinstalled and mounted (servo leads in the cockpit with white dots indicate the three LED circuits to plug into the controller while the control board is an Power Modellbau 2K Flasher unit using a single receiver channel to be operated by the transmitter.
Link to the disc strobes that claim visibility at altitude in sunny conditions…. https://www.hacker-motor-shop.com/Li...PT4143&p=10758
This sailplane will be getting a super cool PowerBox Pioneer unit fed by two 2200 mAh 7.4V lipos and two PowerBox 26D receivers.
VIDEO
I will be building this as an FES using the Torcman system and a Hacker A50-14L motor turning a 14x10 on 10S 4000. Here's a similar setup flown by Ralf at EMS.
