so knowing i will need much weight in the nose to balance what is your suggestions for a 12s power supplied motor and folding prop combo. here is what i know so far.
it is hard to find folding blades over 20"
the nose is short and fat so it will require a wide prop hub so folding can clear the sides.
i might need a linger single bolt prop shaft if the motor doesnt come with such.. small cnc parts can make that if needed.
this will be for flight after tow up not needed for rog so ground clearance is not an issue.
any input welcome please....
thanks in advance
joe
thanks in advance
joe
