H9 ASH 31 build, notes and questions
    commented on 's reply
    Or you can order them directly from The Model Box that has them in Stock!
    205 978 8787
  • BryanB
    Straight hinges from Dubro or Robart will work but if you want actual geardoor type hinges you can contact Sonic Tronics directly and see if they ship to Oz. I've ordered from them before and they were pleasant to work with.
    Hinges for model airplane construction
  • Mark Stone
    Thanks Jeremy, they look like they will do the job.
    But all the stockists in Australia are out of stock.
    I think these may work for you!
    The Model Box 205 978 8787
  • Soaranator
    Robart used to make a similar hinge. Haven't been to a brick and mortar store in ages so have not seen them around latey.
  • Mark Stone
    I have managed to break one of the gear door hinges :-(
    Does anybody know if they are available from somewhere?
    Mark
    Front end work,.... as I was matching the spinner I decided to even things up a bit with finishing putty......and sand off all the anti-collision Orange....
ID:	36688Click image for larger version
    Filling the tow release hole with west systems / #410 micro lite filler.
    Candles.....
    At least the motor mount makes it easy to rotisserie the fuselage for painting.
  • BryanB
    Pretty cool stuff. The T-Bird scheme is going to be awesome!
    IDS install on the Flaps -
    Click image for larger version  Name:	IMG_5017.JPG Views:	1 Size:	52.2 KB ID:	36519Click image for larger version  Name:	IMG_5018.JPG Views:	1 Size:	100.8 KB ID:	36520
    Click image for larger version  Name:	IMG_4985.JPG Views:	1 Size:	49.8 KB ID:	36516Click image for larger version  Name:	IMG_5002.JPG Views:	1 Size:	72.1 KB ID:	36521
    Click image for larger version  Name:	IMG_5015.JPG Views:	1 Size:	38.2 KB ID:	36517
    In preparation for the Thunderbird color scheme - AeroThane #187 Christen Eagle Red
    Click image for larger version  Name:	IMG_4978.JPG Views:	1 Size:	72.5 KB ID:	36518
    Molex MicroFit 3.0 - dual row - 10 pin locking connector for the wing wire harness.
    Click image for larger version  Name:	IMG_4982.JPG Views:	1 Size:	56.9 KB ID:	36522Click image for larger version  Name:	IMG_4965.JPG Views:	2 Size:	60.2 KB ID:	36524
    Great Idea!
  • French1
    Here is a small tun up for the prop to avoid damaging it when you pull back the sailplane by the tail.
    I used a O ring #57 or 35mm diameter and twisted it twice on the prop (on twist on each side of the shaft. Works great! no more damage on the ground or in the car...
    Just need to sand a bit more the fuse to have enought clearance for the O ring
  • danfitz
    PM sent Mosquito!
  • Mosquito
    I would like the full monty.
  • danfitz
    Coming right up Bryan!
  • BryanB
    I'll take a canopy cover.
