Blanik 2.0
    After a slight vertical landing last fall in cumberland, I had to assess the usual stress around the back canopies of the plane.
    Stress is cause by scissors effect between the wing that are stiff so quite heavy and the weak part of the fuse that is between the wings. Too much opening with not enough meat lead to shear...
    Should have done that stiffening before...
    I liked the way Don did on his plane, basically rip the back windows, stiffen the area, a bit of putty, paint and windows are simulated by using black vinyl. Great idea that I duplicated on mine
    At first couple layers of fiberglass and epoxy to fill the holes.
    I used a sheet of mylar on the outside to layup with the correct shape
    Untitled by steffruelle, on Flickr
    Then tearing up the bead of fiberglass tow that join the two haves together (really painful to not damage everything), using scrapping blades and coarse sand paper
    After, lay up of carbon fiber cloth (heavy) as a ring on front and back of the fairings as on the split halves
    And.... Putty and sanding...
      And today was paint time, again, many thanks to my buddy Scott for helping me on this repair
      him at work to blend the edges in after painting and clearing
      And a very usefull for everyone that will do repairs on the fuse, the matching paint using R&M paint is MA145.10
      Should save life of bunch of people
      To be continued
        Now just a tiny bit of vinyl to fake the windows...
        template cut using 5x5mm paper for those who what to copy it
        ET VOILA!
          SWEEEEEEET.
          nice repair
            Oh boy! That looks great! (again)
              When Kevin and I were aerotowing at Harris Hill, I noticed the fuse behind the canopy was getting pretty weak. Sort of copied Stephane in that I took out the windows and fiberglassed all around the inside. Much stronger now. Also got the scale tow release installed. Thanks Gunny.
ID:	8970 Click image for larger version
ID:	8971 Click image for larger version
                Video of last week end flying
                Really enjoying that plane!
                  I see no Video Link French 1!
                    Here it is but you should see the video embeled in the forum, at least it is how I see it in IOS and In chrome
                      Now your first Video Post works!
                    Anyone here find a wheel that will outlast the stock one. I have now gone through 3. No dramatic landings this week, but the brand new wheel cracked and fell off.
                      I see it embeded
                        Csessa, Don and myself are using Sullivan wheels with the aluminum hub.It holding up well for Don so far... I still have to finish mine
                        • Csessa
                          Csessa commented
                          Yes, just got my sullivan wheel in the mail. Used a spare gear assembly drilled out for the proper axle. Will try it Cumberland.
                          Sorry to hijack this converstion.
                        I am about to get Blanik 2.0 myself. On version 1 I used Spektrum A6260 servos for ailerons, flaps, rudder. Seems that servo is no longer available. Suggestions for alternative?
                        Yup, super strong servo.
                          Yes A6265, Horizon is out of stock but I may have some available, let me know if you need them and how many!
