FAA Makes Major Drone ID Marking Change
  • FAA Makes Major Drone ID Marking Change
    Listen-up, you dirty drone jockeys....
    The Federal Aviation Administration (FAA) has posted a rule in the Federal Register requiring small drone owners to display the FAA-issued registration number on an outside surface of the aircraft. Owners and operators may no longer place or write registration numbers in an interior compartment. The rule is effective on February 25. The markings must be in place for any flight after that date.
    When the FAA first required registration of small drones in 2015, the agency mandated that the registration marking be readily accessible and maintained in readable condition. The rule granted some flexibility by permitting the marking to be placed in an enclosed compartment, such as a battery case, if it could be accessed without the use of tools.
    Subsequently, law enforcement officials and the FAA’s interagency security partners have expressed concerns about the risk a concealed explosive device might pose to first responders upon opening a compartment to find a drone’s registration number. The FAA believes this action will enhance safety and security by allowing a person to view the unique identifier directly without handling the drone.
    This interim final rule does not change the original acceptable methods of external marking, nor does it specify a particular external surface on which the registration number must be placed. The requirement is that it can be seen upon visual inspection of the aircraft’s exterior.
    The FAA has issued this requirement as an Interim Final Rule—a rule that takes effect while also inviting public comment. The FAA issues interim final rules when delaying implementation of the rule would be impractical, unnecessary, or contrary to the public interest. In this case, the agency has determined the importance of mitigating the risk to first responders outweighs the minimal inconvenience this change may impose on small drone owners, and justifies implementation without a prior public comment period.
    The FAA will consider comments from the public on this Interim Final Rule, and will then review any submissions to determine if the provisions of the ultimate Final Rule should be changed. The 30-day comment period will end on March 15, 2019. To submit comments, go to http://www.regulations.gov and search for “RIN 2120-AL32.”
    As Transportation Secretary Elaine Chao promised last month, today the FAA also posted proposed new rules to let drones fly routinely at night and over people, and to further integrate them safely into the nation’s airspace. The comment period for these proposals begins tomorrow and will end April 15.
    This is another stupid rule. This from a well known aviation publication.
    "Subsequently, law enforcement officials and the FAA’s interagency security partners have expressed concerns about the risk a concealed explosive device might pose to first responders upon opening a compartment to find a drone’s registration number. The agency believes the new requirement will “enhance safety and security by allowing a person to view the unique identifier directly, without handling the drone.”"
    ......"A concealed explosive device"! Are they kidding me! I can just see someone who would put a concealed explosive device on a drone saying "Hey before we fly this thing lets make sure we put our FAA registration number on the side". Sheesh!
      What if the drone is found on the ground in a position that the number can't be readily seen. Does this mean a bomb disposal unit will get called? If so, will the owner of the 'drone' have to pay for the bomb disposal unit's time?
        This is not encouraging. If the logic of future UAS regulation is this flawed.........
          Per the email the AMA sent out about this:
          AMA will be submitting comments to the FAA requesting a waiver process for those who might be burdened by external markings, such as members who fly scale replica model aircraft.
            As other's have said, no one is going to put a concealed bomb inside the drone and then make sure to update their home address with the FAA while placing their FAA number on the outside of the drone. 100% of people doing something wrong with the drone will NOT have the number, 50% of people doing things safely will have the number. They can't possibly think this is for ID? So, this is about something else.
            With that said I'll be complying as I registered back in 2015. Oh well, I just hope we don't have a Heathrow incident where some innocent AMA member gets shakedown as a scapegoat.
              Someone might steal your FAA number and use it for illicit means! I understand what you are saying but am just being the Devil's Advocate in this foolishness!
            • pete914
              pete914 commented
              I hear you ARUP!
            2pt font on the bottom of my stab...
ID:	34989 I had Callie Graphics make up 50 of these black letters on clear vinyl....the lettering is 1/8" high in size for $10.00 I plan to put these under stabs etc. small but visible. Some of the fields I fly at will require this and I want to be able to fly anyplace I show up. Sucks but what can one do. Just an idea.
              • SoarHead
                SoarHead commented
                I had Callie do mine in white. Impossible to see unless you know where to look.
              Might I use 'invisible' ink? Specifically, the ink that only shows with UV light? The Federal specs don't address this as 'yay' or 'nay'.
              Also, any club that voluntarily wishes to enforce FAA policy (for free!) is just enabling the FAA to extend their 'reach'. The FAA wants to pass rules and regulations so let them enforce them! We are required to have a valid AMA number to fly at most clubs and sanctioned AMA events and we must now have a valid FAA number to fly... anywhere... with or without the AMA.
              In any case, if a club is going to voluntarily enforce FAA rules and regulations then I, personally, would like to know that will occur. I will base my judgement on that and other factors whether to take time to attend said event.
                Mike...you might just find yourself with very very few places to fly in the end...sucks I know.
                  It’s all “Kubiki” Theater anyway.....there’s no way they can enforce any “no fly” edicts they impose on the public........the kind of flying we do will never stop no matter what any government bureaucrat dreams up as an answer to an unasked question...........treat it like the BS it is and just keep having fun!
                    More like Sesame Street Theater!
                  No club that I am a member or know of is, or is planning to do the governments job of enforcement. Any violation doesn't come back on the "club" so why would they? If any club chooses to self enforce the FAA number rule they are struggling for purpose.
                    Exactly! Only paranoid clubs would be would be willing to succumb to doing the FAA's 'dirty work'! What idiot would put their name or identification on a UAS and do intentional harm? The only scenario is if the miscreant stole your I.D. to do such.
                  Not really because none of the clubs around here act as agents for the FAA. We use common sense and let them do their own work.
                    Back when I started in RC one needed a license to operate a RC transmitter. I never saw a FCC agent nor was I ever asked to produce that license...I still obtained one though. However, that requirement went away long ago. Some say it did because of the CB craze. Now we need something equivalent just to fly. With it being almost impossible to police I wonder if the same will occur with the current knee jerk reaction of our brain dead legislators...or will they drive us all to pick up RC sailboats?
                      For what it is worth, I absolutely love RC sailboat racing and do it a ton more than flying. Don't knock it till you try it...check out American Model Yacht Association for clubs near you.
                      One design racing is incredibly intense and challenging and I would be pressed to chose which I love more.....seriously...quite a bit like pylon racing or slope soaring...reading air is absolutely necessary and sail tuning is critical...try going to some national championships in a given class...it will blow your mind as to the intensity and the challenges......seriously...
                      • Mark9
                        Mark9 commented
                        I understand fully about sailboat racing. FWIW, I raced full size sailboats for years. My first race was in a Santana 20, then started in the "J" series from 22's to the 29. I even leased a J 22 for a year and raced it in the local J 22 circuit. The pinnacle of my racing was a Henderson 30 as foredeck and we raced one design at Key West Race Week. Had some great rides that week!
