Legacy Turbo Duster
  • Legacy Turbo Duster
    I am looking to replace a Multiplex Mentor tow plane with a 65" Legacy Turbo Duster. The Mentor was good for sailplanes up to 4-5 pounds I expect the Turbo Duster to be good to 6 Pounds or so.Has anyone used this plane as a tow plane?
    Jim Gallacher
    No experience with this model, so we will be anxious to hear how it works out. If looks count, it should be a winner because it sure is cute!
    Here is a link to the Extreme Flight page: http://extremeflightrc.com/65-Turbo-...me_p_2171.html
      How about the 40 sized one from Horizon Hobby? It's a little bigger at 80" span and once you get the electric motor you want it would probably be about the same $$$.
        One of our local guys built an electric version of the Hangar 9 Pawnee 40 ARF. It was an okay tow plane, but was a bit tricky to fly. If you rapidly applied throttle, it had a nasty tendency to torque roll. The larger Pawnee is a docile plane with no such bad habits.
        The long tapered nose of the Turbo Duster should be much better than the fairly large blunt nose of the Pawnee.
      The reason for the size (65") is for the ease of transport with other planes in my Rav4.
      Thanks for the input.
      Jim
        I now have the Legacy Turbo Duster in my position. Very well built and covered. However the cockpit is so far aft if I try to install a tow release at the rear edge of the wing it would be almost at the top of the cockpit. Is there a rule of thumb regarding the position of the tow release above the thrust line?
        Thanks Jim
          Hi Jim,
          Congrats on your acquisition.
          You may have to go to the side fuse tow release position. Some have made a Y bridle that connects to each side of the fuse and meets into one line at of the rudder. I've never seen one in person, but I know a few guys in Australia use this method.
          The release servo would sit in the center of the fuse with a simple tube and pin out each side of the fuse. Thrust line is never much of a concern with most models. Obviously the closer to the thrust line, the less pitch change you would feel with different sailplanes.
            Thanks Len
            Does the Y bridle come together behind or in front of the rudder?
            Jim
              Behind the rudder, far enough back so the rudder will move in between
