H9 33% Pawnee Tug Conversion
  • stevekremer
    More questions. Trying to line up cannisters. I have to move the engine box back to the line (about an inch) to fit the cowl correctly. There is an overlap between cannisters and headers? What am I doing incorrectly? Also, how does one get a bolt through the header with such an angle in the header? See photos. Thanks and Happy New year.
ID:	6035 Click image for larger version
  • stevekremer
    OK, got the shock support area reinforced - first picture
    Also added ply to the rear landing gear block - second picture
    and added ply to the front of the front landing gear block - third picture. Think that should be strong enough?
    Now starting to mount engine. New question? The servo cut out for throttle is on top, but the DA120 throttle linkage is on bottom - fourth picture. Where did you guys mount the throttle and choke servos.
    Also, The choke arm seems to be in an orientation that will not work. will it rotate?
  • stevekremer
    Thanks Steve - This will be helpful.
    I was just cleaning up and deleting files on the computer and this one should live on here. Photo is the canister bay modification done by Len to my 33% Pawnee.
  • lenb
    You probably dont want to see this,
    But this is what happens when you roll into the little rut that runs along the bottom edge of the crossing runway in Cumberland back in 2012
    The repair was excellent, although I would use thinner plywood next time. I did cut big lightning holes in the plate after it was installed and before it was covered to help reduce any weight I could. This plane is sensitive to extra weight. If you keep it light, it will AUTO LAND. ( no kidding )
ID:	5989 Click image for larger version
ID:	5990 Click image for larger version
ID:	5991 Click image for larger version
ID:	5992 Click image for larger version
ID:	5993 Click image for larger version
ID:	5994 Click image for larger version
ID:	5995 Click image for larger version
ID:	5996 Click image for larger version
  • stevekremer
    Thanks Peter. I got the shock box supported as you did. I am trying to come up with a way to support the landing gear pivot bearing blocks I will get a picture when I get it glued in. Thanks.
  • Xroadie
    Originally posted by stevekremer View Post
    Got the Plywood cut and realized I cant box in the rear langing gear mount. That is where the wing bolt goes. I think I will put a ply piece on the bottom of the fuse as reinforcement.
    Steve, I don't think adding ply to the bottom of the fuse will solve the issue. I added a "doubler", in front of and behind the "box" that the shocks mount in. Yes...you have to knock out the blind nuts front and back to do this....but you will want to upsize the bolts anyway which means going with larger blind nuts...so it's not an issue. I upgraded to a 10/32 bolt with a long shank....so the shocks aren't riding on threads. Having the long shank also means you'll have to drill the threads out of the front blind nuts, so that the new bolts will pass through and thread into the rear blind nuts. The front blind nuts essentially become a bearing. I will try to post a pic of what I did later. I did basically the same thing Len did.
    Peter
  • lenb
    The release looks good!!!
    You can add a little more support on the sidewall if you feel its needed, then use a little longer bolt.
  • stevekremer
  • stevekremer
    Finally getting busy on the Pawnee. I have the wings and struts basically finished. Got the release installed in the fuse and am planning reinforcement of the landing gear area. Reading all the posts without pictures is difficult. I am thinking that boxing in the two landing gear beams and beefing up the shock mount area will be sufficient. I read some post about adding a bulkhead, not sure where this was intended to go.
    Attached are photos of release and gear mounts (indicated with the green tape) I plan to box in with ply and tri stock. Any other comments or pictures would be great. Especially pictures of canister area.
  • lenb
    Hi Steve,
    White Rose Engineering makes nice units. Not cheap, but very high quality. http://www.whiteroseeng.com/products/
    For 1/2 that price you can get an Ohio Superstar http://www.ohio-superstar.com/
  • stevekremer
    What tail wheel do you all recommend. The old posts said that the stock tail wheel system is JUNK. So, what is a good one? Thanks.
  • Xroadie
    I like that welding rod idea Stew! Maybe next time. I had a piece of 1/8" music wire that I cut to length. The original release's rod and clevis were threaded for 3mm, so I decided to reuse the clevis and locking nut that came with it. I had a 3mm stainless socket head cap screw that was left over from mounting the release to the bulkhead, so I used an 1/8" bit to drill out a pocket in the head of the cap screw, then silver soldered the cap screw on the end of the pushrod. It works great! Tow release done
  • Stew
    A good source of 3/32 and 1/8" rod is welding rod. 3/32 will easily accept 2-56 threads and 1/8 will accept 4-40 threads. A long time ago, I bought a kit called Rod-Chuck I believe. It is simply a set of dies to hand thread the welding rod. Very simple. They start with a size bigger thread but of the same pitch, so for 2-56, you first thread the rods with a 3-56 die and then rethread with a 2-56, similarly for 4-40 threads on the 1/8 rod, you first run a 5-40 die and then a 4-40 die. There is to much material to be removed to go straight to the smaller dies. None the less, in the end you end up with very strong rods of a diameter we can easily drill holes for, and when you use the weld rod for control rods, they all end up the exact custom length for super clean installs. The down side is that most people don't want to take the time to cut and thread welding rod, but I have found no better solution to getting really strong control custom control rods.
    Here is the link to RodChuck.
    Pete,
    The units that came with the Porters had a pushrod that was larger diameter than 4-40 pushrod and it matched the hole in the release. The most recent unit I got from Esprit had a smaller pushrod, as you describe, but the aluminum part had the same size hole as the Porter units. I kind of wondered about the sloppy fit, but used the unit in my most recent Decathlon with no issue. The unit that came with the Bidule has the heavier rod, but the hole diameter is smaller toward the top half. Seems like hole was drilled part way from the bottom with a larger diameter bit and then from the top with a smaller bit. Actually, a piece of 4-40 rod works perfect, but the included rod will not fit up through the upper hole.
