Seafoam won't change the properties of the fuel, only clean out the gum that might have shown up. that being said............Non-Ethanol should be fine.
Auto gas doesn't stand the test of time that avgas does.
Tow Plane gasoline
Fuel was ok. I think the broken header was unrelated to the gas.
it will be fine and should you need more be ready for sticker shock
Sell it on the street. “Psst, hey mister, I got 7.5 gallons of primo Arabian unleaded that will rock your world. Let me hook you up.”
Divide the amount into two equal parts...let Kevin test his 3.75 gallons against the performance of your 3.75 gallons. Each sailplane pilot can do a series of test tows with each of you. After five days of aerotowing, they can report any difference observed from previous tows with the same tow plane using fresh fuel. At that point, you will have no other choice than replacing your supply.
Tow Plane gasoline
Kevin and I loaded up 7.5 gal of non ethanol tow plane fuel in November prior to Cumberland. We were unable to attend. Did not put any stabilizer in the fuel. So, now it is 4 months later.... Opinions on whether to use it, or get rid of it and get fresh fuel? Thanks.Tags: None
