I thought I'd start a thread on real world experience with engine and prop combos.
I don't have any verifiable data, I'm wondering if anyone else does. In the old days, Robin Lehman kept a journal of engine/prop RPM's and thrust(lbs) collected via a fish scale attached to the tow release. It is long gone, I guess, and there are a lot more engines and props available so the info would be dated anyway.
From that early information, I have always run a 26x10 on a 100cc size motor. Never had any real reason to change as far as I could tell, so I've pretty much stayed with wood in that size. An occasional CF would slip into the picture but cost was a factor and I also like the fact that wood breaks easier; yes, I know, an odd reason, but I somehow tell myself that it is somehow safer, at least for the engine.
I balance my props but wood just never seems to run as smoothly or spool up the way a CF prop does.
While I was @ Clover Creek, Skip mentioned that he thought a Mejzlik CF 27x10 might be a better match for the DA100 as the blades are thinner and the prop is stiffer and balanced better.
Thoughts overall? What engines/props are you running and do you have any data?
