California Smelly...yak 2
  • Mosquito
    commented on 's reply
    Settle down Michael.......
    Oh yeah...baby!
    Starting to look presentable.....
ID:	35800Click image for larger version
ID:	35799Click image for larger version
    Foam shaping to fit the winglet.....
ID:	35787Click image for larger version
ID:	35788Click image for larger version
    Thanks Gunny,
    Winglet fun....going to make a plug/mold for the winglets from blue foam so Hotwire templates ( Formica ) were made and stuff was cut.
ID:	35772Click image for larger version
ID:	35773Click image for larger version
    Using PSU 94-097 winglet airfoil
ID:	35779Click image for larger version
ID:	35777Click image for larger version
    Since I was over zealous sanding the cut ridges and sanded off the top trailing edge, fiberglassing it so I won't put too many dents in it.
  • gunny11
    Whoo that's a nice looking wing. Love the flap extension.
    Plugging away .....Horizon....definitely a... maybe.....
    Flaps - bottom hinged, top actuated and 55 degrees. Outer flap goes to Rib 7. Estes 1/2" rocket tubes for servo wire containers.
ID:	35766Click image for larger version
    +1 I hope it is ready for Horizon!
  • BryanB
    Looking awesome Obi Wan!
    Mockup Winglet to check sizing and shape. The TL90 digital pitch gauge makes it easy to get the right angles.
ID:	35234Click image for larger version
    Using construction paper and 1/8" sq balsa to reinforce.
ID:	35233Click image for larger version
    Outer Flaps and Aileron. Staying with the bottom hinge setup on the outter flap . Drilling the hinge holes I thought was going to be a bit challenging , but turned out not to be a big deal.
    Using the handle end of the 3/16 round file ( sharpened up a little ) does a great job of drilling matched holes.
    Click image for larger version  Name:	IMG_4905.JPG Views:	1 Size:	94.8 KB ID:	35222
    Built the flap and aileron against trailing edge of the wing for a better match, using 0.060 shims in between the surfaces for spacers. And a jig at the wing tip for a matched aileron tip for minimal sanding.
    Click image for larger version  Name:	IMG_4906.JPG Views:	2 Size:	94.0 KB ID:	35226Click image for larger version  Name:	IMG_4908.JPG Views:	1 Size:	107.5 KB ID:	35227
    Top hinging the aileron for a smoother look
    Click image for larger version  Name:	IMG_4909.JPG Views:	1 Size:	63.8 KB ID:	35224Click image for larger version  Name:	IMG_4910.JPG Views:	1 Size:	52.8 KB ID:	35225
    Time to work on the Winglets........
    And more clamps.......Was a bit paranoid about inducing any twist into the wing while attaching the lower D-box skin so I decided on the "gravity method again.......small wedges on each rib to push the skin up.
    Click image for larger version  Name:	IMG_4900.JPG Views:	1 Size:	107.5 KB ID:	35098
    Attaching the Trailing edge stock.....I'm running the flaps to Rib#7 ( 2 more bays ) to give the wing a 60/40 split ( flap/aileron ) and since I'm going to have winglets the ailerons will be more effective at the tip ( at least that's what I'm telling myself )
    Click image for larger version  Name:	IMG_4901.JPG Views:	2 Size:	128.1 KB ID:	35100
    Getting closer to the wing tips.....clamp-O-rama
ID:	34933Click image for larger version
    No Adjustments,.....in for a penny ... in for a pound ....as the saying goes. the wheels should be just behind the leading edge of the the wing ....which should be pretty stable
    Finishing up on the right center section.
    Do you have a way to adjust the gear in case it wants to nose-over too readily?
