California Smelly...yak 2
  • Waiting for paint to dry.....
    • I guessed correctly on the dolly height and successfully installed the wings with the landing gear installed.
      Of course, the winglet and stabilizer were unnecessary for the test.....but.........
ID:	39652 Click image for larger version
ID:	39651 I would have installed the other wing but I spent too much time ogling and it got dark........
        VS. the high clearance original
        • BryanB
          BryanB commented
          Very nice touch..
      • what did you use to bond the brass wire to the collar and the other wires
        • The 1/8" brass tubing was glued to the collars using West System/ 404 high-density Adhesive filler. I drilled holes in the collars for a little extra surface area contact and mechanical structure.
          The cross bracing is just silver solder attachment after contouring the tubing to try to match the mating surface.
          Precision drill hole duplication.
          Click image for larger version  Name:	IMG_5472.JPG Views:	0 Size:	98.3 KB ID:	39689 Click image for larger version
Name:	Fender posts no glue.jpg
ID:	39692 Click image for larger version
Name:	Fender posts.jpg
          • thanks i guess hysol can do the trick also.. very nice work
            • Vent for the gas tank and buttoning up the canister compartment
ID:	39838 Click image for larger version
              • Coolest build thread ever....😎
                • Thanks Pete for a great kit and all the support....
                  The more parts I put together....the slower I progress
                  • Fabulous Scot
                    • There will be some really cool tow planes at Montague this year...😜
                      • Amazing job Scot...almost time to start the L-19
                        • Scot, Amazing job on your version... Love the nose and wheel wells!
                          Almost time to finish the 1/3 scale 2-33
                          • Can't wait to see pics of your "SmellyShark" in action. Or at least all put together.. .
                            • Photo shoot Sunday
