While towing at the recent MRCA Aero Tow in Ann Arbor, Michigan, my DA-120 powered Decathlon suddenly got very loud. I knew right away what had happened because I have had a similar thing happen on a different model...the header pipe had broken.
Pre-made Header Pipes typically have a section of flex pipe built into them so minor adjustments can be made to lineup the header pipe with the muffler.This flex section is typically wrapped with layers of white Teflon pipe thread tape.
After considering various options, I decided to try repairing the break with a sleeve made from a piece of pipe I had ordered when making the custom header for my DA-85 Porter. The DA-85 header pipe is larger in diameter than the pipe used for the DA-120 headers. After some grinding and filing, I got a section of this pipe to fit over the broken area while keeping the shape and length of my header the same. The section was silver soldered in place and wrapped with new Teflon tape. I found Teflon tape made for gasoline pipe joints...not sure if this will make a difference, but we will give it a try.
sorry this one is out of focus, but this is how the joint looked after scrubbing it with a Brillo pad.
