Guys, How can I get a good estimate of servo power needed in a glider? In this case, the glider will have 17 servos, and eight of them will be driving the ailerons. The switches I'd like to use (Zepusu magnetic) are only rated for 15amps each. The glider will have two switches controlling power to two receivers. That appears to mean that about 8-9 servos will be powered by one switch. How do others determine what kind of current levels will be seen in their gliders before it is all wired up so true current levels can be measured? I'm not really looking for worst case estimates that could occur, but what is likely when all is "normal".
Larry Fitch
Larry Fitch
