Hi Al
The panels I mounted on my new trailer are secured to an aluminum L channel which is riveted to the trailer roof supports. Doing this allowed me to use the stock location on the panels for mounting them.
A few words of advice.
The 100 Watt system is a good way to keep a battery topped off and charge some packs, however you will not be brewing coffee with them. I'm running a 200 watts and two 105Amp AGM batteries through a 3000 watt inverter and its not enough for the Kurig. Unless you can find a low draw coffee maker, its better to bring a generator or a cup with you.
Also, you'll want a distribution panel which will house your fuses. Even with the simplest setup, you'll want to have it fused. Jim can send you in the direction of a low cost panel.
If you're looking for more power, I have a NIB panel system from Harbor Freight that I did not use.
