WindyHill Hobbies 60" Swift
    And an Ahi
    • mlachow
      mlachow commented
      Stop surfing the internet and build.
    Fair enough, at hospital now taking care of Covid patients... 👍
ID:	43662 I added some black stripes to the bottom of the wing. Ailerons are now hinged and pushrods completed. With a little bit of nose weight, the model finished up at 27 ounces
      I do need to add a little weight to one wing tip. The wood for the ailerons was very different density. I used the aileron push rod wire but I didn't like the clevis that came with the kit. I soldered on a threaded brass piece to use with Sullivan clevis.
      The only thing remaining to do is paint the canopy.
        I finally put in a few flights on the Swift. It flies nicely but the 15 to 20plus at Cumberland was on the high range the stock model can handle a zip start lainch. A few flutter problems zip starting out into the lift band. I plan on changing the stock horns with something sturdier. The slip on retainer on the horn on one wing came loose. I might move the hook back to get more climb and less speed with a zip start for Cumberland.
        I built it light weight. Maybe some monokote will help There is some info on building it heavier by adding strapping tape as well as monokote.
          So the hill was too windy for the Windy Hill??
        • mlachow
          mlachow commented
          Zip start was too much for windy hill. Pretty much most of the foamies there were fluttering with that zip start. Would have been OK on a hill you are just chucking it from. They do have suggestions for adding more tape and weight for windy conditions.
        I put some oratex on one wing panel, 45 degree bias. It adds about an ounce to the wing panel and looks a lot nicer than EPP. Way stiffer.
