Hi Arup,
hi Arup,
I like the way the plywood sheeting turned out, once varnished/finished.
Good idea on using bass (or spruce) on the ribs.... my gut sense is that something other than balsa is needed for the outline (top and bottom), largely to deal with "hanger rash". I think balsa on the uprights would be pretty strong though.
Interesting fluids you have used for fillers on fabric, such as milk.
Ever hear or have experience with using gelatin?..... such as Knox (I think now owned by Kraft), used in some food preparations.
I tried it on a test sample of Koverall and it filled really well and left a hard surface but did not take the experiment at the time to further finishing.
Your finished model is a dazzling accomplishment of a very unusual subject.
Michael in Ontario, Canada
hi Arup,
All new brake lines and brakes installed including a dual circuit master cylinder in lieu of the single which is stock. Disc brakes going on front. Dot 5 silicone fluid going in the reservoir. Ya gotta be able to stop especially when a little car like this gets triple the horsepower from stock!
Will get venturi built up, too!
