1/4 Scale ​1954 Scheibe Bergfalke Mü13 E build
    Marc, thanks! Of course, this wouldn't have happened without you, Chris Williams, Cliff and offering the Bergfalke Mu 13 E kit on scalesailplaneskits.com
      Additional mods to the nose area, just getting it right.
      Cockpit area behind pilot seat cross-bracing. Added pedal foot rest and wood screws to attach floor
      Aerotow nose servo location (using S3003 for mounting only, Graupner metal gear servo will replace)
        Getting profile just right makes or breaks! I like how you are creating the cockpit details with dowels, floor and etc. Eye candy!
          Location of elevator stabilizer servo. Carbon fibre arrow shaft push rod
          Carbon fibre arrow shaft push rod exit at base of fin location
          Now I need to start building again.
          Cheers, Thompson
            Hi I got the lasercutsailplane just need to get a list of what wood l need to build this mode with when look on the plan l can not find what l want online do you have a list of wood you used or no were l can get a list from
            it looks amazing plane and can't wait to get started
            Edward
              I can look into creating a list of what I've used to build this. Unfortunately, I'm still only at the stage of where I've stopped on the last photo above. Hopefully this will help you at least to this point.
              Cheers, Thompson
                Thompson, Edward's first post so ya gotta come through!
                Edward, please do a build. This isn't one you see every day! Two builds will be awesome!
                  Agreed, it would be nice to have two building here! tedrocks123 - I helped with the conversion of traditional hand drawn plans to CAD for laser cutting. I've also made some small scale corrections to the nose while building the fuselage as noted in my thread.
                  Cheers, Thompson
                    Thompson, you need to get back to the build!
                      I agree Thompson, its been too long.
                        Thanks for the words of encouragement, I definitely need to get this vintage sailplane build back on track!
                        Cheers, Thompson
                          Just started build, your
                            Hi Just started build, When do you get to the wings can not wait, But I will.
                              Broders - I'll be starting on the wings soon, finishing up the fuselage first.
                              Fuselage to do
                              - Elevator shaping on top
                              - Painting inside of cockpit frames
                              - Tail build
                              - Servo mountings
                              - Cockpit details
                              Will be posting photos of the wing spars, parts and build sometime soon, stay tuned.
                              Cheers, Thompson
                                Go get-em Thompson!~!!!
