Completed the wing-side wiring this week. Not going into details since it is pretty straightforward stuff, other than to say all servos are wired separately (no shared power hookups - one wire, one Multiplex connector pin). Using PowerBox premium wire and servo connectors exclusively. I really like their stuff.
The Jeti solder boards for Multiplex green connectors are the shizzle. I no longer dread soldering up these connectors. One piece of advice...when soldering the boards to the connector, make sure you have the opposite side plugged in. The pins "float" a bit in the shell, and having the connector mated holds them in proper alignment.
