so is there a secret to rebuilding a let wing locking assembly that is built into the fuse. it has a spring with 2 balls that click into the wing male spike for attachment. on one side the spring will not return back to retain the balls when not in sue and when in use the wing will not feel clicked into the balls with pressure from the spring.. it is not an adjustment of the wing insert side as i have taken it off the wing and tried it by hand still no locking to hold going on.
let after a week and 2 emails fails to respond... hope for help here.
my option is to cut the female spring side built into the fuse and leave a shoulder to have the wing threaded rod pass through and use a washer with wing nut for retaining the wing root to fuse.
