Great work, Tom. Add yaw string, balance and you're good to go!
FW Models ASW-17 is here!
Spent the past few days working on detail bits. Wing tip wheels required a bit of re-profiling work on the base, then painted them with automotive urethane. The airframe is also supplied with very scale wing linkage fairings, in the event one uses a top-exit arrangement (as I did).
Finally, added the call sign...double X-ray flies again!
5 PhotosTom
Tom, as always, was very thoughtful and thorough in his description of his build and all of that effort has really been a gift. I can't thank him enough.
I only diverged from his build in one way: driving the elevator with two servos. Likely overkill on my part but I wanted the peace of mind that a redundant setup brings.
While I started out trying to put two thin wing servos in the tail, it ended up being a multi-day fools errand so I decided to use independent bellcranks driven by carbon pushrods attached to servos behind the main landing gear. This method ended up taking quite a bit of real estate in the tail so I will have to use a pushrod for the rudder as well. All of this likely saves a bit of weight in the tail but, for a glider of this size, likely won't matter much.
The only thing I did remotely Watson-worthy was to use these pushrod guides from McMaster-Carr to support the pushrods mid-way down the fuselage:
McMaster-Carr is the complete source for your plant with over 595,000 products. 98% of products ordered ship from stock and deliver same or next day.
And a link to the pushrods purchased from Goodwinds Composites:
PCT .315" x 48" Pultruded Carbon Tube - 5/16 inch structural composites for aerospace, industrial components, sports equipment, hobbies
The bellcranks were fashioned from 3/32" G10 with some carbon reinforcement. The bearings are brass tubing.
MikeLast edited by yyz; 08-04-2020, 01:26 AM.
