Csec modelarze! Here is the other cable run. The wire TE was put in place. The aluminum tube to capture the wire was too long at the aileron end of the wing so it was re-slotted and trimmed. The wire was bent to let it anchor into the rib then the aluminum tube 'ears' were peened over the wire. Epoxy secures it. The wire stock is too short so the other end was secured in like manner. The aluminum tube's hole had to be 'stretched' to fit a second wire whose ends were secured, likewise. The wing root rib's TE got 1/64" ply pieces at its TE top and bottom surface to help hold the wire in place. When the covering goes on the wire TE will pull into a gentle scalloped shape.
more...
more...
