I am putting together a new KV 4.8 meter Ventus 2CX. Since the servo I originally selected for the supplied retract system will not work I started a new search. While discussing it with a flying buddy he said he has been using a Spectrum A7040 #SPMSA7040 in his ASW-20. It is a 160 degree servo with adjustable end points, most retract servos are end to end only with no adjustment abilities. It might work for my application, since I believe I can adjust the end points in my transmitter. However, it is an analogue servo and some will work with FHSS-3 ATX receivers, while others will not. The only way I know to find out if it works is to try it, $40 gamble. Do any of you know if it will work with my 10 channel FHSS-3 receiver? Below, I have posted my description and requirements of my application.
"What I need is a low profile, 130 oz/in. to 200 oz/in. (minimum), metal geared, ball bearing and 6 V. or High Voltage digital servo. Speed does not matter that much, that can be adjusted by my SD-10G. I currently have installed a Savox SC-1251MG and with my servo tester I can get the required travel at 0.8-2.2 msec. pulse width. However, when using my transmitter, an SD-10G with the end points and maximum travel set a 150% that travel cannot be achieved. The manual states the pulse width range of my transmitter is 0.9-2.1 msec. pulse width.
I cannot simply increase the servo arm length due to existing structure limitations and supplied mechanics. BTW, I could add a longer servo arm, but that would require fabrication of an adapter to replace the one supplied with my model; not beyond my abilities, but not preferred. The servo must be compatible with a Sanwa FHSS-3 receiver and if need be I would also require a programming tool, if a programmable servo will work. BTW, I have no experience with programmable servos. Is there a servo and what tool/tools are required that can solve my problem without fabricating the new adapter?"
