Hey all,
Stephane has done the lion's share of the work building custom wings for my EDF powered DG 200 build. I'm converting a Reichard models' 1/4 scale DG 300 to the old-school 17 meter DG 200/17.
I have never built a wing and I need some assistance/input.
To-do list:
1. bond and shape leading edge strip. Advice please on techniques that are best for a beginner. How much should I trim back? How do you keep a perfectly flat surface as you are cutting back? What should I use to bond it? Best way to make sure I maintain this critical part of the airfoil when shaping it? Is it true you can purchase preshaped leading edges?
2. Wing joiner dihedral. What's the simplest way to get the desired dihedral? I believe this one is 3 degrees
Stephane has given me a lot of info and instructions but I'm starting this thread and want everyone's input....hopefully it can keep me motivated to get it done!
