Does the little special tool just glide along the bottom inside skin/ hinge without cutting though? It just removes excess foam and cleans out the trench?
Arcus/Duo/Janus/Nimbus
MikeOriginally posted by ARUP View PostDoes the little special tool just glide along the bottom inside skin/ hinge without cutting though? It just removes excess foam and cleans out the trench?
in fact the trench is cleaned before using a flat screwdriver, the tool allow to dig a small trench in the fiberglass below the veneer.
layup is wood / FG / Peel ply / FG / FG / Foam
On the outside you need to go through the veneer and FG and from the trench you need to go through the double layer of fiberglass to free up the peel ply
Clear enough?
StéphaneStéphane
Yes peel ply is the hinging materialOriginally posted by ARUP View PostThe peel ply is the hinge? I always thought the peel ply was just used to get exterior finish and was discarded but you have used it differently.Stéphane
Second part of the job...
First carving the foam on the wing side in order to make a pocket where the future moving surface lip will slide in
Untitled by steffruelle, on Flickr
Then lay up of two layers of 1.5-2oz fiberglass. Less easy as it seems as the tape will fray!!!
Then as second layer of balsa, slightly narrower than the first one that close the moving surface in order to allow the moving surface to move properly
A bit of carving, first using a sanding block and then using 80 grit sand paper in the gap between the moving surface and the wing. Leave a comfortable gap in order for the covering material to not bind on the wing
ET VOILA!
CLOSE
OPEN
Lets get these wings done!
Tip added, usual method, a thin plywood between LE and TE plus some balsa top and bottom.
This avoid the tip when they are balsa only to be dented
Et voila
StephaneStéphane
Janus is back at the top of stack of work..
Program of today : servo pockets
I just drill corners then use metallic roller with xacto knife to open them and using a rotary tool to crave the foam out.
Then come the time to shape a piece of plywood in shape for having the servo flush on the lower surface
presure is your friend..
and here we are, just add a plywood cover and two screws and it is done!
Starting on the fuse,
first the stab holder simple piece of plywood with two bind nut, a bit of 5mn epoxy to put it in place and some slow epoxy with filler and cotton fiber to lock it place
then the servo holder that is also used as the fin stiffener (very very important!) to avoid fin stress.
Control of geometry
the magic plywood ..
And a bit of compression for a good bond and geometry
Time to move to the landing gear
first cutting the doors, I use for this a metal ruler and the back of an xacto knife then a hack saw
Couple former to hold the undercarriage, and a tray for the rudder servo
a bit of epoxy and FG
Doors are hinged with bicycle tire tube glued with CA
tabs for the door end point
Then gluing the tube to the fuse with slight stretch, it will allow the door to close by themself
Et voila!!! (click on it to see the video)
Nice retract mount and cool trick using wingnut and bolt in slot for servo adjustment... correct?
Now let tackle the tow release.
As I am planning to install a motor in the nose, I don't want to use a regular to release, I will use a side to release on the Janus.
I have built a servo holder and moved the servo close to the undercarriage to give me some space in the front of the nose. Servo is a A6265 with 328 oz at 6V, never want again to have too weak of a servo....
I glued a plastic tube on the side of the fuse and made a blob of microsphere and epoxy where I will carve my tow release
And from the outside I created the cavity that I will use as tow release, plastic tuve is on eache side and a piano wire come to lock the loop
Another thing down on this ship, still some more to go but getting closer
You are on the home stretch!
