There is a new update from rc-electronics. I think this one will be hard to avoid since the web sites are changing.
Here is a copy.
First of all, RC Electronics team would like to wish you Merry Christmas and all the best in 2023.
We have been working around the clock to finish the project which were planned for 2022.
We are happy to announce that we launched our newly designed online platform www.rcmodelspot.com, where we supported GPS Triangle Euro Contest, League, local events and challenge cups. More rankings / events will be added in 2023.
At this point we would like to thank again to our donators who helped us financially with the project so we could finish it… THANK YOU
As we moved our platform to new / faster servers and made a lot of changes, it is important to know that all users are required to use new Albatross v3.4. With any older version access to rcmodelspot will not work anymore.
Speaking about Albatross 😊 … Yes, we publish new version… version 3.4 and can be downloaded from our website: https://www.rc-electronics.eu/Albatross_v34.apk
In this version we made:
- audio warning for safety zone is working correctly for all types of zones (circular and rectangular)
- faster save to cloud
- zoom out of map when Fly button is pressed is now fixed
- last state of map enable / disable is remembered and will be same on next flight
- Fix RF option is always visible, even for non-competition signed task
- Cloud settings were removed from setup as GPS triangle league server will shut down in 2023
- Upload of flights for GPS triangle league was removed
- Removed email and replay button in logbook
- Faster response when flying
- All GPS triangle classes are now using barometric altitude for a score.
Last line is very important! We have been contacted from GPS Triangle Committee that new rule change will be active for 2023 which will say that barometric altitude is taken for a score of Altitude and not GPS Altitude anymore. Due to this reason, it is important for all pilots to set navbox where they check altitude to Baro Altitude and not GPS altitude as was used now!
Also, it is very important to update the plane unit and ground unit to latest version where this barometric altitude is calculated correctly (auto set to 0m before takeoff) All units have new versions: v1.5.B0 and are published on our website:
Here is a copy.
