It depends on the size and weight of your sailplane...but even less than ideal lengths can be made to work (so don't get overly stressed about this).
We have experimented with a lot of tow planes and sailplanes and came up with this guide.
Small foam sailplanes, like the Multiplex Easy Glider, which are 2M or less wingspan and about 2lbs. in weight...#18 braided nylon mason line about 60-65' long works very well. The twisted mason line will also work, but the braided line is more durable and easier to work with.
Slightly larger foam sailplanes, like the Multiplex Cularis, which are about 2.5M in span and about 3lbs. in weight...#18 braided nylon mason line about 75' works very well.
The small scale sailplanes in the 2.5-3.0M wing span are tricky to tow for reasons other than the towline length, but, #18 braided nylon mason line about 75-85' works okay.
Scale sailplanes in the 3.0-3.8M wing span are a little easier to tow successfully...and #18-21 braided nylon seine twine about 85-90' long works very well.
Scale sailplanes in the 4.0-6.0M wing span are much easier to tow...#24-30 braided nylon seine twine about 100' long is great.
Scale sailplanes in the 6.0-7.0M wing span range works well with #30-36 braided nylon seine twine about 100-110' long is fine,
Finally, scale sailplanes in the 8.0M+ wing span range work well with #36 braided nylon seine twine about 110-120' long is fine.
These are not absolutes, just the sizes that we have used with good success.
