Sorry, the pictures were not easy to understand how it was constructed. Mine has no solder on the cross bar too. It is also a press fit into the holes where the area is double thickness brass K&S tubing. However, if the holes are a press fit for the cross bar and 1.5 hole diameter minimum from the edge of the part you should be good. The surrounding structure should hold the pin in place. The loads in the expected use are in a direction that will not press out the cross bar, only applying lateral loads to the method by which the bar is installed. It is then effectively a single piece of metal. The only way the cross bar could come out is if it was bent. That would be highly unlikely with a seven pound aircraft on the piano wire of the length and diameter being used.
By the way 1.5 minimum edge distance is the standard engineering practice for safe hole design we used in aircraft structures. Just some of the knowledge I picked up working around aircraft all my career. My first job at the firm I was with was to plan the operations required to build a part or assembly from an engineering drawing. This included what engineering specifications applied to the requirement. The plan was then sent to the shop floor with the words I wrote, the materials, the basic steps/work stations and or machine operations required to produce it. Feel free to ask any question you're not sure of I might have an answer then again I might not. Nobody knows everything, nor can they.
Stopping at the local HS on the way in. Fun day.
